94 LS- Ipod hookup
Old 01-26-07, 02:06 PM
  #31
PureDrifter
BahHumBug
PureDrifter's Avatar
im not using jacks as i want it mainly for ipods, im just running a dock cable to my center console, that way i get clean preamp sound.
Old 02-07-07, 03:27 PM
  #32
JCSOTW
JCSOTW's Avatar
Quote:
Originally Posted by wpai
I just hooked up an earphone jack to the CD(R,L) inputs. I was then able to listen to all MP3 or whatever devices with an earphone plug. Run the wire under gear shaft cover so it looks clean. Sound is of CD quality and no noise at all. If you burn a blank CD it will run great, or you will hear sound breaks at the end of each song.
I've done this in 20 minutes and the component cost is ZERO. A very worthwhile job. :^) My car is 1992 LS400.
So how exactly did you hook up the earphone jack to the CD inputs without cutting the existing wires. You also mentioned earlier that you ran it in parallel with the CD input lines. I have the earphone jack but I need to know exactly how to connect it with or without cutting into the wires.
Any and all info is greatly appreciated!!!
Old 02-07-07, 04:21 PM
  #33
dfkd
dfkd's Avatar
I took care of mine last week in 0 degree weather.
Pretty much you look into the back side (the side that doesnt go into the head unit) of the plug and pop the wire into that side of it on the respective wires.
Now that we're past that horribly confusing explanation...
The headphone wire will be going into the back side of the plug just like the RCA plugs here are going in.
I just used duct tape to make sure that mine stays in place.
I would suggest however that you split the negative wire into 2 and plug them in to both negative cd inputs. On mine I only connected it to one of the cd input negatives and it resulted in my sound being louder on one side and pretty quiet on the other...
Old 02-07-07, 05:20 PM
  #34
PureDrifter
BahHumBug
gimme a couple more days and il have a big guide up on installng a DIY aux. input to any LS400.
Old 02-07-07, 06:07 PM
  #35
akxx
akxx's Avatar
Originally Posted by JCSOTW
So I assume you pulled the head unit out of the console and tapped into the CD R/L wires from behind the head unit?
I'm curious as to whether these wires are accessible from under the center console somewhere, since the CD changer wires run from the trunk into the cabin to reach the back of the head unit, but *where* are they routed?
Old 02-08-07, 06:57 AM
  #36
dfkd
dfkd's Avatar
I never cut any wire at all to do my tap.
I just...tapped...the inputs at the headunit plug and ran the wire from there past the gear shift, and under the edge of the console as near to the side of my seat as i could.
Old 02-08-07, 11:00 AM
  #37
utexas112
utexas112's Avatar
I know you guys are anti FM-Transmitters, but I use a Kensington one and it works great.. very little, if any, static.. easy to use, etc.
Old 02-08-07, 12:46 PM
  #38
akxx
akxx's Avatar
Dude--if you heard the difference between even the best FM transmitter and direct input, you'd throw that thing away!
Old 02-08-07, 01:19 PM
  #39
dfkd
dfkd's Avatar
No kidding...
Seriously, because I can edit the sound output settings on my mp3 player I'd have to say that my mp3's sound even better than the cd changer does.
Old 02-08-07, 03:18 PM
  #40
PureDrifter
BahHumBug
yes but the problem is that FM radio inherently has a MUCH smaller frequency range than CD or direct wiring. U just CANT get the same lows and highs.
https://www.clublexus.com/forums/sho....php?p=2410828
finally got the Hardwired AUX input done
mistermet
01-15-14 11:20 AM
kg19989
05-10-10 07:06 AM
MainStream
09-07-07 09:20 AM
garbage85
General Classifieds
12-04-06 12:36 PM
Quick Reply: 94 LS- Ipod hookup
