New Bushings
Old 01-03-06, 01:53 PM
hyperopt
hyperopt's Avatar
Default New Bushings
Had same time over the holidays to replace some bushings, DIY, on my LS, which fix vibrations at high speed (LCA & stabilizer bar bushings) and during braking (rear axle carrier arm bushings). The work is easily the best time and money I have spent, which yields the most noticable results. I also found one bad UCA bushing which I will replace as soon as I receive the part.
Check those bushings if you have similar symptoms.
Old 01-03-06, 06:52 PM
LSPiNoY
LSPiNoY's Avatar
how much did you pay for your stuff? and where'd you get them? my suspension up front is having a lot of vibrations. but, still runs like a champ
Old 01-05-06, 03:35 PM
hyperopt
hyperopt's Avatar
LCA OEM bushing = $33 ea
Stab bar OEM bushing = $10 ea
Rear carrier aftmrk bushing = $30 ea
Old 01-06-06, 06:35 PM
sahtt
sahtt's Avatar
Thanks for the info. I found out this week I need to replace
A bushing on the rear right, can't remember what it is called but visually it's rear of the axle and farthest down I think [have it written down]. Also repack them(?).
Front right control arm.
Both supposedly need a shop to do them, but I'd like to do them myself if at all possible.
bfigard
06-04-20 12:11 PM
joebor1776
Suspension and Brakes
03-12-16 08:59 AM
Bankswood
09-02-14 06:49 PM
Bradster
03-15-09 05:53 AM
cation
01-31-09 06:02 AM
Quick Reply: New Bushings
