LS400 diff. LSD or not
Old 08-28-06 | 02:18 PM
CELICA XX's Avatar
CELICA XX
I understand that...
I just don't understand how there cannot be a definitive answer in the open vs. LSD mystery.
Old 08-28-06 | 02:54 PM
cip's Avatar
cip
I think the definitive answer is noted above "but the LS400 never came with an LSD - this is quoted straight from Lexus corporate."
One factor not mentioned yet is weight distribution... If you turn off trac and punch it on level ground (or do a brake torque) while facing straight ahead you will most likely get 2 patches. That is b/c the weight to both tires is nearly identical. As the article linked above states " Remember that the open differential always applies the same torque to both wheels"... that's why your open diff can seem like LSD.
However, try turning off trac when it's wet while turning... as you start to move the weight distribution is greater on the outer wheel giving the inner wheel a chance to spin wildly. You will not see that happen with an LSD. (this happened to me this AM but try it if you like)
The fact that good suspenstion, load leveling, and /or other electronic suspention stuff may be in place on your car will keep the weight distribution pretty equal.... that's why you may think you have an LSD..... but you don't
Old 08-28-06 | 03:04 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100000
simple answer is NO.
the LS400 does not and never came with any sort of LSD from the factory.
Old 08-28-06 | 03:36 PM
siamiam's Avatar
siamiam
does anyone make a LSD for our cars? i drive on snow and ice most of the year and it would be nice to have
Old 11-23-11 | 11:27 AM
jrowedem's Avatar
jrowedem
Can you explain this better to an idiot (me)
I've been stuck so many times in my 93 LS, on the ice... only one wheel spinning.
What's the deal ?
Simply the distribution of the grip isn't relatively even..
djpauldc1
Performance & Maintenance
10-29-10 01:28 PM
fastegg
03-28-10 04:46 PM
bzebern
08-14-08 03:51 PM
gs300_r1
GS - 1st Gen (1993-1997)
02-20-05 08:16 PM
chliansh
08-29-02 03:09 PM
