Check out this site!
Dude are you sure Retro,I still kinda of scared 100 shots is to much.If my engine or tranny blows I am screwed I will never have enough money to fix it.
Plus at 100 shots what do I need to add to be safe?
cut off cpu,fuel system upgrade,pistons,gaskets,spark plugs,air to fuel ratio mixer? I do not know jack **** about NOS and I want to be 100 percent safe before I get it installed.
man, just go with ZEX. By far it is the most safe system out there and it is dry. It will give you maximum of 75 shot which would be enough for you (you are too paranoid about it ). If you want to go over 100 shots you better use wet mainfold shot. That will be more precise and you will have to use NOS or Venom nitros kits. Here is the best price you can find on ZEX kit: http://www.groupbuycenter.com/buy.asp?row_id=3157
You won't need a purge kit, but you might want to get a preassure gage so you know when you are out. Get it here: http://www.groupbuycenter.com/buy.asp?row_id=3120
I would defivetely go with Venom 2 stage system, but I am broke
