Brake Fluid indicator light - 92 LS 400
Old 04-20-06, 01:24 PM
suloh
suloh's Avatar
Default Brake Fluid indicator light - 92 LS 400
My Brake Fluid Indicator light stays on all the time, even after I topped it above the full mark. When i disconnect the sensor that comes out from the rubber cap, the light goes away. A new sensor cost $100 so I am thinking of leaving the sendor disconnected (cannot stand the warning lamp).
My question: Is this sensor very important? Should I happen to suddenly lose brake fluid, will there be other warning systems telling me that my brakes are giving me problems?
anyone tried repairing the sensor?
Old 04-20-06, 01:51 PM
MadMax96
MadMax96's Avatar
A system to do that won't do you any good - if you should happen to loose pressure and or fluid rapidly, odds are your brakes won't function and the sensor will be the least of your worries.
Old 04-21-06, 08:13 AM
sha4000
sha4000's Avatar
thats not a good ideal
sam12345
03-16-15 09:39 PM
kwatt1
10-31-11 07:07 AM
mrchacon
06-28-09 10:39 PM
philES300
Maintenance
10-16-06 09:21 PM
azari
12-25-05 06:54 PM
Quick Reply: Brake Fluid indicator light - 92 LS 400
