clunking noise when breaking
Old 04-22-06, 05:42 PM
Bercasio
Bercasio's Avatar
Default clunking noise when breaking
Not sure if this is a re-post, When I apply the breaks it makes this one time "clunk noise", and when I release and break again the sound repeats, then I release and break again. I can do this about 3-4 times applying the break and let go, apply again, etc, from there it goes away. it only happens when I will be drivin' for a few minutes and needing to break....I only hear this in the front driver side....anybody have any suggestions? I had Daizen bushings put in about 2 years ago, and had JIC SF-1s' then I sold those and put back my stock ones for now. Till I receive my JIC FLT-A2s'. Therefore could it be the bushing wore out on the bottom stock suspension/strut? Or is it something else?
Old 04-22-06, 11:28 PM
vsynergy
vsynergy's Avatar
I have the same problem, but I have no clue what it is.
Old 04-23-06, 12:08 PM
LexCelsior
LexCelsior's Avatar
Exclamation
I too have the same problem. Help us CL experts!
I have cali custom 2" lowering springs with Tokico shocks. Bushings were replaced with OEM Lexus bushings a while back. It feels like it's coming from the brakes.
Old 04-23-06, 04:17 PM
RA40
Super Moderator
RA40's Avatar
Sounds like the infamous caster/strut bar bushing. Could be an upper or lower ball joint, tie rod, upper or lower control arm bushing. If none of these has been replaced start first at the strut bar bushing. Mine were going south at 60K miles. Some do better than others but IMO many of these rubber parts are going to have wear or age issues by 100K.
Strut/caster bar replacemnts are about $120 each and labor per side is going to be about 35 minutes. You'll need an alignment afterwards so add in another $75.
About the only things I have left to do on mine are the lower control arm bushings and replace the upper control arm including the upper ball joint which comes with the arm. Then I'll have done the whole front.
I think GrandLS4 has done his whole front end.
Old 04-23-06, 04:19 PM
biglexass
biglexass's Avatar
i have the same prob to.does it effect anything or hurt anything?
Old 04-23-06, 06:38 PM
sonyman
sonyman's Avatar
For the record, it's "brake". I've seen this many times, and its beginning to annoy me.
Scott
Old 04-23-06, 11:25 PM
panos
panos's Avatar
My 1994 has started doing this. More loud on pax side. Doesn't yet have 60K miles, so these bushings basically age quicker by age than by usage.
Old 04-25-06, 09:08 PM
Bercasio
Bercasio's Avatar
Scott
Ooops!,,,,you are correct!......for you to be annoyed, you must be a great "En-Grish" teacher, who is also a great "En-Grish Spoker!"... .......besides all that, I will look into the ball joints, along with the sway bar bushings and strut bushings. As for the control arms, there is Daizen bushings installed, so i know for sure it's not that!.... Thanks for the info boys!
Old 04-26-06, 09:32 PM
e-man
e-man's Avatar
Scott
For the record, it's "it's" not "its" "beginning to annoy me."
Old 04-27-06, 09:22 PM
jcrome04
jcrome04's Avatar
i have the same noise going on. i dont know much about that front end stuff but i was told i need some new wheel bearings. . .probably along with all that other junk oh well it's part of having a car. plus big heavy wheels aren't to nice to those parts
Old 05-05-06, 01:47 PM
steveski
steveski's Avatar
It may not apply to your car but my 2nd gen was doing the same thing and it turned out the caliper bolts were loose. It may not be the problem but it takes a few minutes to check.......?
Old 05-05-06, 03:08 PM
sonyman
sonyman's Avatar
LoL. My bad there.
Scott
Kozy
07-26-15 05:12 PM
fransattle
12-07-07 06:48 PM
tvd51
11-08-04 12:45 PM
vuvu
SC- 1st Gen (1992-2000)
17
04-06-02 01:02 AM
Quick Reply: clunking noise when breaking
