RPM and Temp gauge does not work
Old 04-26-06, 09:09 PM
LexusLimit
LexusLimit's Avatar
Default RPM and Temp gauge does not work
The rpm and temp gauge does not work on a 90 ls400. How can I fix it?
Old 04-27-06, 05:48 PM
clean95
clean95's Avatar
use the search button
Old 04-28-06, 09:24 AM
LexusLimit
LexusLimit's Avatar
I try the search button and didn't find anything, but if you can find it for me then that would be great.
Old 04-28-06, 01:07 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
maybe you just cant read?
look at the very first thread in the forum. covers all the problems with the gauges.
Old 04-28-06, 05:16 PM
LexusLimit
LexusLimit's Avatar
maybe your a little herb. I read the first thread and it doesn't cover everything. None of them relates to my problem. It just does not work period.
Old 04-28-06, 10:11 PM
PureDrifter
BahHumBug
you read all 10 pages of this??
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/40025-instrument-cluster-circuit-board-is-bad-1000-bucks.html
then my mistake, you can read, you just cant understand whats in front of you.
(and yes, i just realized its the 2nd from the top but still)
Old 05-01-06, 08:53 AM
LexusLimit
LexusLimit's Avatar
https://www.clublexus.com/forums/showthread.php?t=40025
Obviously you can't understand whats in front of you because the sticky above did not explain the step by step instructions of how to fix it. It just tells you where to send it. If anyone does have first hand experience or If you do understand, then maybe you can explain to me the step by step instructions of how to fix it. The RPM needle and temp needle does not move, but all the lights work perfectly.
Jmac1773
16
06-06-22 12:57 PM
michael69
13
11-26-10 11:55 PM
UCF11
07-29-08 02:33 AM
Iansaltes
12-04-07 06:51 AM
PuppyDawg
GS - 1st Gen (1993-1997)
05-27-05 04:07 PM
Quick Reply: RPM and Temp gauge does not work
