Cleaning MAF 91 LS 400
Tried cleanin the MAF but I could not find the wire. Located the MAF which is just after the air filter. Instead of removing the whole MAF from the car, I uncliped the plug attached to the MAF and then unscrewed the 3 small screws and pull up the module. What I found is this rectangular plastic piece but could not located the wire. DO I have to remove the entire assembly to clean the MAF?
Originally Posted by PureDrifter
your better off leaving the MAF alone and cleaning out the throttle body.
Scott
