235/60/16"
Old 04-28-06, 01:55 PM
finetune00
finetune00's Avatar
Default 235/60/16"
i just saw four alloys off a 98 LS,on ebay but could they fit an92 LS the 98"s are 235/60/16"inches.Would i still get a smooth ride on them.could sombody tell me what to look for when the trans feels light?
Old 04-28-06, 09:37 PM
trukn1
NELOC Mod
trukn1's Avatar
not sure if the rims will fit, as I have a 92 myself. As far as tire size, it will fit under the fenders without rub. Is your car at stock height or lowered?? If lowered you will rub in the tops of the fender well. I currently run 225/60/16 and have a 1"drop. mine rubs over large bumps. As long as rims match up fitment wise, at stock height the tire size is fine. The ride will be greatly improved and cornering will be greater.
Old 04-28-06, 10:04 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
those arent stock tires sizes for a '98 LS. stock size is 225/60/R16
Old 04-28-06, 10:35 PM
trukn1
NELOC Mod
trukn1's Avatar
I don't know what the stock size for 98 is, but if it truly is 225/60/16 then they will fit fine with no problem at stock height. That is what I run now, and even at 1" lower height, I rub over large bumps. With lower height , should have run 225/50/16 so have no rub. this is pic with 225/60/16. at 1" lower height.
Attached Thumbnails 235/60/16"-102_0498.jpg
IrunRICH
IS - 1st Gen (2001-2005)
10-13-10 07:20 PM
tadslc
Wheels, Tires & Brakes Forum
06-09-03 01:33 PM
joedoe
02-24-03 07:28 PM
videofxr
20
03-01-02 04:35 PM
Quick Reply: 235/60/16"
