Manual trans for an LS 400?
Been searching for a while, haven't found a specific answer.....Is it posible to swap a manual trans from something else (sc tacoma etc.) into a 90 LS 400....link or pics are appreiciated.
Certainly the Toyota racing development guys have had some successes with manual transmissions on a UZ-FE block.
Fairly Certain that there are SC-400's that are manual. Not sure on the GS-430.
Ok then is it the same bell housing in the LS and the SC and maybe the GS? if so I think I have found most of the info..... need further for ecu/tcu stuffs(mostly wiring) Most definatly a Couple of SC's gone manual.
Just a thought the LS is a V8 and the sc IRC is a v6
Im not sure what they did about the ecu to trick it just look for RIDES episodes about a IS 300 with a GS 430 motor swap I am not sure which episode it is but i have it on DVR and can get you a date it was aired
simple answer, there is no NON-custom way to fit a manual trans onto a 1UZ. no factory toyota manual transmission bellhousing will fit to the 1UZ.
that being said, it is possible, but both expensive, time consuming, and fairly complicated.
VSsc400 did a manual conversion in his SC400
https://www.clublexus.com/forums/sho...ual+conversion
Technics
07-14-08 08:47 PM
1995, 1998, 400, 400s, conversion, custom, gerabox, ls, ls400, manual, navigation, swap, tran, trans, transmission
