How do I remove a passenger side door rear view mirror
Old 05-06-06, 12:33 AM
BLUECHIPS
BLUECHIPS's Avatar
Unhappy How do I remove a passenger side door rear view mirror
Hi
Can any one tell me how to remove a passenger side rear view mirror, woman driver adjusted my original one? Never removed one before.
BLUECHIPS is offline
Old 05-06-06, 12:53 AM
skperformance
skperformance's Avatar
What is a wing mirror?
skperformance is offline
Old 05-06-06, 02:23 AM
BLUECHIPS
BLUECHIPS's Avatar
Talking passenger door rear view mirror
Hi
Its a passenger door rear view mirror in the UK we call it a wing mirror.
Old 05-06-06, 09:57 AM
Luxury_LEX
Luxury_LEX's Avatar
Originally Posted by BLUECHIPS
Hi
Luxury_LEX is offline
Old 05-06-06, 04:18 PM
trukn1
NELOC Mod
trukn1's Avatar
Post
Hi
Not that hard to remove.
1. look under the mirror to the base that the mirror sits on, near body of the car
2. you will have to use an offset phillips head screwdriver to remove the 2 screws that attatch
the mirror the mirror base. these will be hard to turn at first because they are sealed with
thread lock. (offset screw driver has phillips head setup at either end of the driver and set at
90 degrees at each end) not expensive---- $5 - $10 tops.
3. entire mirror housing will come loose and into your hands. depending on your year, you may be able to disconnect the wire harness from outside of the car once you get mirror loose, otherwise you will have to remove the inside door panel and fish around to find harness.
trukn1 is offline
Old 05-11-06, 12:39 PM
trukn1
NELOC Mod
trukn1's Avatar
No problem Blue. I had to take my mirrors loose from the base to hide the wires for my turn signal covers. (didn't want them exposed). Will check out manaual. Might be the same one I purchased from ebay for $11.
trukn1 is offline
Apothist
ES - 5th Gen (2007-2012)
07-02-18 11:04 PM
740ilsamue
02-10-16 10:57 PM
maxx430
10-20-14 01:23 PM
horent135
SC- 1st Gen (1992-2000)
07-12-08 11:44 PM
minh
GS - 1st Gen (1993-1997)
06-08-04 09:16 AM
Quick Reply: How do I remove a passenger side door rear view mirror
