Headlamps - Auto Off? 92 LS 400
Does the 92 LS 400 have an auto off feature for those that forgets to turn off the headlamp?
I have forgotten to turn off the headlamps quite a few times - somehow the bright display makes me forget the the headlamps are still on. Usually, the next morning, when I go to my car, headlamps are off but the car starts with no problem. This lead me to believe that the car might have some battery saver function that cuts off power to headlamps once the battery drops below a certain voltage.
However, the car started not being able to start when I leave the headlamps on overnight by mistake.
What is the world is going on??
The thing is that my headlamps do not turn off when I pull the key from the ignition.
This all makes sense now. The is probably a relay that turns of the headlamp when you remove the key from the ignition even if your headlamps are on. Perhaps that relay is not working which results on my battery draining,
Anyone out there know which relay we are talking about? And where that relay is????
Thanks
Thanks
Originally Posted by trukn1
You may have another problem going on there. I have a 92 myself and my lights go off when I remove the key from the ignition, if I don't turn them off. I have a feeling that something else is pulling constant drain off of that battery.
That relay may be in the drivers door on the side pillar, I never really paid that much attention to it. I know that when I pull my key out of the ignition and/or open the drivers door, all lights go out. It has become such a smooth progression to me that I never really noticed before. Have door sensor relay checked.
Just went out to check. Yes, the headlamps go off the moment I pull out the key and open the door. Question is why does the light stay on sometimes. Could be the door sensors not working. Any other triggers that may turn on the headlamps? How about the alarm system.
With the auto sytem on, the lights are switched off when the door is opened. They will only come back on (In normal functioning) when you manually turn the light switch on the stalk or by sensor when the ignition switch is <ON>. I usually leave my lights on so it is activated by the ignition being <ON>. I dunno why the engineers designed the lights this way but it has been a feature as far back as my '85 MX73 Cressida.
Nope, I think it's a little more simple than that. I have this same problem and I've narrowed the problem down to the door sensor sometimes being "sticky". By sticky I mean when it is pushed in (car senses door is closed) it does not come out all-the-way when the door is opened so, the car still thinks the door is closed.
This would be the same sensor that activates the interior lights right??
There is no other drain on the battery except when I accidentally leave the headlamps on and the Auo Off function is not working..
Yeah, I've also left my lights on thinking they've shut off automatically. Good thing I've been fortunate enough that my car has been able to start after every instance. I've also had problems with my dome light not turning on when my door is open so these two must be linked together. I'll have to check that sensor in the door that you guys have been talking about. Where is it located?
cant remember exact location. open door, feel along the door frame on the car, not the door, towards the closest to the back of the front seat. You should feel a button like object the protrudes from the frame and gives way when you push on it. that is the sensor.
