car shuts off while driving
Old 06-12-06, 06:32 PM
99LS400BLK
99LS400BLK's Avatar
Default car shuts off while driving
today when i was driving the car shut off on me. when i came to a stop sign the car completely shut off and i had to put it back into park and start the car again. this has happened a few times already. has this ever happen to you guys? what is the problem?
Old 06-12-06, 07:56 PM
biglexass
biglexass's Avatar
yes it happends every time i turn the a/c off and the very next stop it stalls.its a low idle issue.thats all i know.hardly anyone knows why it does this but this problem has been popping up alot more on these 1gens.
Old 06-12-06, 08:46 PM
CO-LS400
CO-LS400's Avatar
Default Mass Air flow sensor
It may be a mass air flow sensor.
If its faulty it can cause the car to stall??
Old 06-13-06, 08:07 AM
sha4000
sha4000's Avatar
the MAF could be the culprit, but you also might need to clean out your throttle body and clean out your fuel injectors. i would recommend a complete tune-up
Old 06-13-06, 10:29 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
I would get some Throttle body cleaner, adn clean the MAF, and the TB... should notice things smooth out a bit.
Old 06-13-06, 01:11 PM
ychachad
ychachad's Avatar
distributor could be going as well. check dist rotors, if they are corroded then their resistance buildup will be very high. As temps increase, resistance goes up even further. As you slow down, there is just not enough current flowing through to the plugs to keep her going. Hence she dies. Another classis sign would be, when she is at operating temp, if you give her full gas, she hesitates a bit and then takes off.
Also check your spark plugs for fouling/wear, cracked insulation, and change spark plug wires.
Old 06-13-06, 03:32 PM
lexusnutt
lexusnutt's Avatar
Major thread on this issue at the "other Lexus site"
http://us.lexusownersclub.com/forums...howtopic=15699
Old 06-13-06, 07:26 PM
601LEXTACY
601LEXTACY's Avatar
YO. i had the problem. Ignition coils is the key. I gaurantee.
BGG
05-16-14 09:47 AM
silverlexg
10-29-12 07:54 AM
adreano17
07-22-12 01:19 PM
NaturalJZ
Performance & Maintenance
08-24-11 10:17 PM
LittleMous
25
02-25-08 12:40 PM
Quick Reply: car shuts off while driving
