Strutbar Question
Old 06-25-06, 10:19 AM
Majkmil
Majkmil's Avatar
Default Strutbar Question
Hi, I have a 98LS400 with 73K. I got two new strutbars from park place Lexus in Tx. I was going ti install these myself but I think it may be a little beyond my skills. Do you think I will have any trouble brining the parts to a mechanic and have them install them? And how many labor hours do you think this job will take? Thanks Mark
Old 06-25-06, 12:10 PM
Suneet
Suneet's Avatar
You bought a rear and a front upper strut bar? The front upper strut bar is really simple, you just open the hood and it bolts on. I'm not sure about your car, but the rear may require removal of the backseat, but after doing that, it should be a bolt on as well. I'm sure someone else with a 2nd gen LS will chime in.
Old 06-25-06, 12:13 PM
Lexkost
Lexkost's Avatar
No such thing as a upper rear strut bar for 2nd LS.
Old 06-25-06, 01:07 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
yup yup, only rear lower chassis braces available for UCF20 cars.(read ~$400 from TOM'S)
Old 06-25-06, 01:48 PM
Majkmil
Majkmil's Avatar
I'm refering to the front suspension strut rods that connect the lower supensiom arm to the body. Sorry I was not clear.
Old 06-25-06, 08:20 PM
RA40
Super Moderator
RA40's Avatar
The strut/caster bars are torqued to 121 ftlbs and if you can get the car rasied up enough to get a good position, it can be done. I had a shop install mine and they were in-out in about 45 minutes. The labor cost was $210 which included alignment.
Old 07-09-06, 12:48 PM
steveski
steveski's Avatar
Do you have a photo of them? When you get them installed, let us know what the difference was from OEM. I installed a Tom's STB with springs and struts - drives sporty now. I am thinking of buying the Tom's components up front.
gman808408
Suspension and Brakes
09-24-06 03:17 PM
25
07-26-01 07:19 AM
gwu128
07-12-01 04:11 PM
Quick Reply: Strutbar Question
