HELP..1993 LS400 Replace Bulb- Tail light
Old 07-11-06, 03:38 PM
L-Sports
L-Sports's Avatar
Default HELP..1993 LS400 Replace Bulb- Tail light
Please help..
I am trying to replace some bulbs in my rear tail light. I opened up the trunk but it look like a "wham, bam, thank you m'aam" type of job.. before i start (a i will probably break something), can someone give me help?
Old 07-11-06, 04:28 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Its very straightforward... just proceed carefully.
Old 07-11-06, 09:26 PM
CUMan
CUMan's Avatar
The bulbs that are inside the tail lights that are part of the trunk lid can be accessed through openings on the interior of the trunk lid. These bulbs are very easy to replace.
To replace the outer bulbs, you have to remove the tail light assembly. First, remove the plastic trim along the top of the trunk lining. Then pull the trunk liner away from the tail light assembly. This will give you access to the nuts that hold the tail light assembly in place. A deep well socket will be helpful. I don't remember the size of the nuts and exactly how many there are.
After the nuts are removed, pull out on the tail light assembly. It can be difficult to remove because there is an alignment guide which has a very tight fit. Just keep pulling on it. After you separate the assembly a few inches from the car body, you can easily access the bulbs.
Old 07-12-06, 08:56 AM
L-Sports
L-Sports's Avatar
Thanks CUMan!!
Old 07-12-06, 10:19 AM
NewLSlover
NewLSlover's Avatar
http://www.luxurymods.com/tutorial10.htm
You can use that as a script to actually get to the bulbs...then installing the bulbs is common sense....
Hope it helps
-Sean
Old 07-13-06, 09:11 AM
L-Sports
L-Sports's Avatar
Thumbs up
You Rock NewLSlover!! Thanks a bunch!!
Old 07-13-06, 07:35 PM
KilaWombat
KilaWombat's Avatar
Were you able to get the change done? How long did it take?
Old 07-14-06, 02:28 PM
L-Sports
L-Sports's Avatar
I will let you know Sunday evening.. Monday at the latest!!
Old 07-19-06, 02:06 PM
L-Sports
L-Sports's Avatar
I only had to replace one bulb.. but it took me about 20 minutes.. probably faster if i wasn't so **** about pulling things out!!
THANKS GUYS FOR ALL YOUR HELP!!!!!
Old 07-20-06, 10:33 AM
NewLSlover
NewLSlover's Avatar
You sound like me...I'm **** as hell, I check...then re-check...then check once more before I close it...and I still usually forget to reinstall those damn black rubber things!!!
Good job though, LSport.
Are they LEDs you installed, or just bulbs?
Old 12-10-18, 07:58 AM
rcmlr
rcmlr's Avatar
Default Trunk tail lights
I need to replace the tail lights in the trunk lid on a 2000 LS. I opened the compartments and see the two bulbs. How do the bulbs release?
Old 12-10-18, 08:57 AM
timmy0tool
timmy0tool's Avatar
you need to remove the single Philips head screw holding the bulb housing to the outer lens.
you don't need to unplug the wiring. there is enough slack to get the housing to slide out and hang there while you pull out the bulb.
rcmlr (12-11-18)
txjeff
IS C
02-16-14 08:23 PM
nickvillan
SC- 1st Gen (1992-2000)
01-30-10 10:09 PM
AntES300
07-31-09 09:12 PM
infa_red
01-11-08 04:26 PM
1994es300
01-19-03 07:16 PM
Quick Reply: HELP..1993 LS400 Replace Bulb- Tail light
