I have Car Fax for 1 month...
Toyota LandCruiser:
GOOD NEWS! Carfax search results confirm this 1997 Toyota Landcruiser (JT3HJ85J8V0175043) qualifies for the $5,000 Clean Title History Guarantee. By ordering this Carfax Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
Section #: Section Name: Section Results:
Vehicle Specifications JT3HJ85J8V0175043
Title Check Clean Title History Guaranteed
Odometer Rollback Check No Odometer Rollback Detected
Problem Check No Problems Found
Registration Check Checked 7 types of vehicle registrations
Vehicle History Details 3 Total Vehicle History Records Found
NOTE: Carfax has not inspected this vehicle. It may have problems that have not been reported to Carfax.
How did Carfax analyze this vehicle's history?
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
Country Mfg.: JT3HJ85J8V0175043
4D Sp Ut Utility
4.5L L6 EFI DOHC 24V
Gasoline
4-wheel Drive
Normal
Japan
GOOD NEWS! Carfax search results confirm this 1997 Toyota Landcruiser (JT3HJ85J8V0175043) qualifies for the Carfax $5,000 Clean Title History Guarantee. Carfax analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
Problem Titles Checked: Results:
Salvage/Junk Checked - No Salvage/Junk Title Found
Rebuilt/Reconstructed Checked - No Rebuilt/Reconstructed Title Found
Flood Damage Checked - No Flood Damage Title Found
Damage Disclosure Checked - No Damage Disclosure Found
Manufacturer Buyback (LEMON) Checked - No Manufacturer Buyback Found
Exceeds Mechanical Limits (EML) Checked - No EML Found
Not Actual Mileage (NAM) Checked - No NAM Found
NOTE: Click here for a complete Carfax Glossary.
GOOD NEWS! Carfax search results on this 1997 Toyota Landcruiser (JT3HJ85J8V0175043) did not uncover a potential odometer rollback. Carfax analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
No Reported Odometer Readings
GOOD NEWS! Carfax search results on this 1997 Toyota Landcruiser (JT3HJ85J8V0175043) did not uncover any of the following problems:
Problems Checked: Results:
Accident Checked - No Accident Record Found
Salvage Auction Checked - No Salvage Auction Record Found
Failed Emissions Inspection Checked - No Failed Emissions Record Found
Fire Damage Checked - No Fire Damage Record Found
Crash Test Vehicle Checked - No Crash Test Vehicle Record Found
Grey Market Vehicle Checked - No Grey Market Vehicle Record Found
Carfax search results on this 1997 Toyota Landcruiser (JT3HJ85J8V0175043) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Registrations Checked: Results:
Lease Checked - No Lease Registration Found
Rental Checked - No Rental Registration Found
Government Checked - No Government Registration Found
Taxi Checked - No Taxi Registration Found
Fleet Checked - No Fleet Registration Found
Commercial Checked - No Commercial Registration Found
Non-Profit Checked - No Non-Profit Registration Found
The Carfax database contains a total of 3 vehicle history records on this 1997 Toyota Landcruiser (JT3HJ85J8V0175043):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
06/28/1997 Georgia
Motor Vehicle Dept.
Marietta, GA
Registered as private vehicle
08/07/1997 Georgia
Motor Vehicle Dept.
Marietta, GA
Title #33164272
Title or registration issued
06/01/2000 Georgia
Motor Vehicle Dept.
Atlanta, GA
Title #7142001531001
Ownership transfer reported
NOTES:
You have significantly reduced your risk of purchasing a vehicle with a hidden problem. However, Carfax has not inspected this vehicle. There could be other potential problems with this vehicle that have not been reported to Carfax.
Not all titles issued represent a change in vehicle ownership. For example, a title could be issued to reflect an address change or correction.
PRINT AND SAVE THIS GUARANTEE ALONG WITH THE FULL REPORT
A Three-Year, Transferable Protection Plan
Carfax's $5,000 Guarantee confirms this 1997 Toyota Landcruiser (JT3HJ85J8V0175043) has a Clean Title History. This certificate is valid for three years from date of issue, and is transferable!
Carfax $5,000 Clean Title History Guarantee Terms:
Vehicle ID Number (VIN): JT3HJ85J8V0175043
Year/Make/Model: 1997 Toyota Landcruiser
Issue Date:
11/06/2001
Expiration Date: 11/06/2004
Three-year Protection Plan:
During the next three years, should you discover a problem title in this vehicle's history which was not included in this Carfax Report, Carfax will pay you 10% of the vehicle's wholesale value - up to $5,000!
Transferable Protection:
This Guarantee is transferable should you sell this vehicle prior to the Guarantee expiration date. The new owner receives the same protection plan coverage for the balance of the Guarantee's term.
*Carfax agrees to pay to the holder of this report 10% of the wholesale value of the car, up to $5,000 if Section 2 of this report indicates a Clean Title History and a Problem Title actually exists for this vehicle. A Problem Title is defined as a passenger motor vehicle ownership document issued by the state that bears the word or symbol signifying that the vehicle was salvaged or junked; rebuilt or reconstructed; flood damaged; disclosed as damaged; bought back by the manufacturer; odometer exceeds mechanical limits; odometer was not the actual mileage; or any other symbol or word of like kind. Guarantee Certificate along with corresponding full report must be presented in order to be eligible for payment.
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
4D Sp Ut Utility
Gasoline
4-wheel Drive
Normal
Japan
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
06/28/1997 Georgia
Motor Vehicle Dept.
Marietta, GA
08/07/1997 Georgia
Motor Vehicle Dept.
Marietta, GA
Title #33164272
06/01/2000 Georgia
Motor Vehicle Dept.
Atlanta, GA
NOTES:
Issue Date:
11/06/2001
Originally posted by tacshose
thanks, you just saved me $15.00
CPEREZ100,
I'll take you up on your Carfax offer. I bought my LS used (it's too late now) and did not use Carfax. I'm wondering what the report would say. Here' the vin:
JT8BH22FXT0045030
THANKS!
JT8BH22FXT0045030
THANKS!
Your
CARFAX
Vehicle History Report
CARFAX VEHICLE HISTORY REPORT SUMMARY
* GOOD NEWS!
Carfax search results confirm this 1996 Lexus LS400
(JT8BH22FXT0045030) qualifies for the $5,000 Carfax Clean Title History
Sect.# Section Name Section Results
1 Vehicle Specifications JT8BH22FXT0045030
1996 Lexus LS400
2 Title Check Clean Title History Guaranteed
3 Odometer Rollback Check No Odometer Rollback Detected
4 Problem Check No Problems Found
5 Registration Check Checked 7 types of vehicle
registrations
6 Vehicle History Details 6 Total Vehicle History Records Found
How Carfax analyzed this vehicle's history:
Carfax checks the VIN against its nationwide database containing
over 1.58 billion vehicle history records. The Carfax database
includes U.S. and Canadian title and registration activity, rental and
lease usage, odometer readings from inspection stations, auto auctions
and other sources.
SECTION 1 CARFAX VEHICLE SPECIFICATIONS
Vehicle ID: JT8BH22FXT0045030
Yr/Mfg: 1996 Lexus LS400
Model: LS400
Body: 4D Sedan Large car
Engine: 4.0L V8 MPI DOHC 24V
Fuel: Gasoline
Driveline: Rear-wheel drive
Aspiration: Normal
Country Mfg.: Japan
SECTION 2 TITLE CHECK
* RESULT: GOOD NEWS!
Salvage/Junk-------------------------> No Salvage/Junk Title Found.
Rebuilt/Reconstructed----------------> No Rebuilt/Reconstructed Title Found.
Flood Damage-------------------------> No Flood Damage Title Found.
Damage Disclosure--------------------> No Damage Disclosure Found.
Manufacturer Buyback (LEMON)---------> No Manufacturer Buyback Found.
Exceeds Mechanical Limits (EML)------> No EML Found.
Not Actual Mileage (NAM)-------------> No NAM Found.
SECTION 3 ODOMETER ROLLBACK CHECK
Carfax search results on this 1996 Lexus LS400
(JT8BH22FXT0045030) did not uncover a potential odometer rollback. Carfax
Date Reported: Odometer Reading:
10/04/1996 68
09/17/1999 48,226
10/08/1999 48,302
12/20/1999 48,303 Reported on 10/10/1999
SECTION 4 PROBLEM CHECK
(JT8BH22FXT0045030) did not uncover any of the following problems:
Accident-----------------------------> No Accident Record Found.
Salvage Auction----------------------> No Salvage Auction Record Found.
Failed Emissions Inspection----------> No Failed Emissions Record Found.
Fire Damage--------------------------> No Fire Damage Record Found.
Crash Test Vehicle-------------------> No Crash Test Vehicle Record Found.
Grey Market Vehicle------------------> No Grey Market Record Found.
SECTION 5 REGISTRATION CHECK
FYI: Carfax search results on this this 1996 Lexus LS400
(JT8BH22FXT0045030) identify the types of state motor vehicle department
Lease--------------------------------> LEASE REGISTRATION FOUND.
Rental-------------------------------> No Rental Registration Found.
Government---------------------------> No Government Registration Found.
Taxi---------------------------------> No Taxi Registration Found.
Fleet--------------------------------> No Fleet Registration Found.
Commercial---------------------------> COMMERCIAL REGISTRATION FOUND.
Non-Profit---------------------------> No Non-Profit Registration Found.
SECTION 6 VEHICLE HISTORY DETAILS
The Carfax database contains a total of 6 vehicle history records on this
1996 Lexus LS400 (JT8BH22FXT0045030).
Date: 10/01/1996
Information Source:
Arizona Motor Vehicle Dept.
Scottsdale, AZ
General Comments:
Registered as commercial lease vehicle
Date: 10/04/1996
Odometer Reading: 68
Information Source:
Scottsdale, AZ
Title #T2ZR962770167
General Comments:
First lien reported
Date: 09/17/1999
Odometer Reading: 48,226
Information Source:
Auto Auction
General Comments:
Sold at auction
in Pacific Southwest Region
Listed as a fleet vehicle
Date: 10/08/1999
Odometer Reading: 48,302
Information Source:
California Inspection Station
Stanton, CA
General Comments:
Passed emissions inspection
Date: 11/02/1999
Information Source:
California Motor Vehicle Dept.
San Dimas, CA
General Comments:
Title issued
First lien reported
Date: 12/20/1999
Odometer Reading: 48,303
Information Source:
San Dimas, CA
General Comments:
Title issued
Odometer reading recorded on 10/10/1999
CARFAX
* GOOD NEWS!
1996 Lexus LS400
registrations
and other sources.
Model: LS400
Fuel: Gasoline
Aspiration: Normal
Country Mfg.: Japan
10/04/1996 68
09/17/1999 48,226
10/08/1999 48,302
Date: 10/01/1996
Information Source:
Scottsdale, AZ
General Comments:
Date: 10/04/1996
Information Source:
Scottsdale, AZ
General Comments:
First lien reported
Date: 09/17/1999
Information Source:
Auto Auction
General Comments:
Sold at auction
Date: 10/08/1999
Information Source:
Stanton, CA
General Comments:
Date: 11/02/1999
Information Source:
San Dimas, CA
General Comments:
Title issued
First lien reported
Date: 12/20/1999
Information Source:
San Dimas, CA
General Comments:
Title issued
Can you Carfax this car for me.
Hello,
Can you car fax this car for me. It is a 1998 SC400. VIN JT8CH32Y0W1001757. Thanks a lot.
James
James
here you go James...
GOOD NEWS! CARFAX search results confirm this 1998 Lexus SC400 (JT8CH32Y0W1001757) qualifies for the $5,000 Clean Title History Guarantee. By ordering this CARFAX Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
Vehicle Specifications JT8CH32Y0W1001757
1998 Lexus SC400
NOTE: CARFAX has not inspected this vehicle. It may have problems that have not been reported to CARFAX.
How did CARFAX analyze this vehicle's history?
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
Country Mfg.: JT8CH32Y0W1001757
1998 Lexus SC400
2D Cpe. Mid-size car
Gasoline
Rear-wheel drive
Normal
Japan
GOOD NEWS! CARFAX search results confirm this 1998 Lexus SC400 (JT8CH32Y0W1001757) qualifies for the CARFAX $5,000 Clean Title History Guarantee. CARFAX analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
NOTE: Click here for a complete CARFAX Glossary.
GOOD NEWS! CARFAX search results on this 1998 Lexus SC400 (JT8CH32Y0W1001757) did not uncover a potential odometer rollback. CARFAX analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
08/31/1998 117
08/22/2001 44,110
08/24/2001 44,117
GOOD NEWS! CARFAX search results on this 1998 Lexus SC400 (JT8CH32Y0W1001757) did not uncover any of the following problems:
CARFAX search results on this 1998 Lexus SC400 (JT8CH32Y0W1001757) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Lease Checked - Lease Registration Found
The CARFAX database contains a total of 6 vehicle history records on this 1998 Lexus SC400 (JT8CH32Y0W1001757):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
08/01/1998 Washington
Motor Vehicle Dept.
Redmond, WA
08/31/1998 117 Washington
Motor Vehicle Dept.
Redmond, WA
Title #9824317808
First lien reported
Registered as lease vehicle
09/06/2000 Washington
Motor Vehicle Dept.
Redmond, WA
Title #9824317808
First lien reported
08/22/2001 44,110 Auto Auction
Sold at auction
08/24/2001 44,117 California
Inspection Station
09/14/2001 Washington
Motor Vehicle Dept.
Redmond, WA
Title #9824317808
First lien reported
1998 Lexus SC400
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
1998 Lexus SC400
Gasoline
Rear-wheel drive
Normal
Japan
08/31/1998 117
08/22/2001 44,110
08/24/2001 44,117
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
Motor Vehicle Dept.
Redmond, WA
Motor Vehicle Dept.
Redmond, WA
Title #9824317808
First lien reported
Motor Vehicle Dept.
Redmond, WA
Title #9824317808
First lien reported
Sold at auction
Inspection Station
Motor Vehicle Dept.
Redmond, WA
Title #9824317808
First lien reported
Carfax
I am interested in this 1997 Lexus Ls 400 (JT8BH28F8V0080305). I would appreciate if you could run a carfax. Thanks.
Hi, could you please run a carfax on this Lexus ES300. Thanks
VIN = JT8BF28G4W5051225
Vehicle Specifications JT8BF28G4W5051225
1998 Lexus ES300
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
Country Mfg.: JT8BF28G4W5051225
1998 Lexus ES300
4D Sedan Mid-size car
3.0L V6 SFI DOHC ALUM
Gasoline
Front-wheel Drive
Normal
Japan
GOOD NEWS! CARFAX search results confirm this 1998 Lexus ES300 (JT8BF28G4W5051225) qualifies for the CARFAX $5,000 Clean Title History Guarantee. CARFAX analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
GOOD NEWS! CARFAX search results on this 1998 Lexus ES300 (JT8BF28G4W5051225) did not uncover a potential odometer rollback. CARFAX analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
06/29/2000 40 Reported on 09/19/1998
07/10/2001 63,108
10/02/2001 63,686
10/23/2001 63,736
GOOD NEWS! CARFAX search results on this 1998 Lexus ES300 (JT8BF28G4W5051225) did not uncover any of the following problems:
CARFAX search results on this 1998 Lexus ES300 (JT8BF28G4W5051225) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Commercial Checked - Commercial Registration Found
The CARFAX database contains a total of 6 vehicle history records on this 1998 Lexus ES300 (JT8BF28G4W5051225):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
09/01/1998 Florida
Motor Vehicle Dept.
Boca Raton, FL
10/12/1998 Florida
Motor Vehicle Dept.
Boca Raton, FL
Title #76257274
Title issued
First lien reported
06/29/2000 40 Florida
Motor Vehicle Dept.
Boca Raton, FL
Title #0076257274
Title issued
First lien reported
Odometer reading recorded on 09/19/1998
07/10/2001 63,108 Auto Auction
Sold at auction
in Southeast Region
10/02/2001 63,686 Auto Auction
Sold at auction
in Central Region
Listed as a dealer sale
10/23/2001 63,736 Auto Auction
Sold at auction
in Central Region
