Strange Vibration in the Rear
Old 07-31-06, 11:42 PM
yusych
yusych's Avatar
Default Strange Vibration in the Rear
Hello, I have a 1991 LS400 w/53K. Now my problem is when i accelerate from about 20-35 mph i feel a mild vibration in my rear end, now i was woundering what that can be or how can i find out, thanx
Old 08-01-06, 02:20 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
did u just get tires rotated/balanced/replaced?
Old 08-01-06, 07:01 AM
yusych
yusych's Avatar
no not yet
Old 08-01-06, 11:18 AM
ls400boi
ls400boi's Avatar
check you either your transmission mount or the drive shaft bushings.
Old 08-05-06, 11:22 PM
yusych
yusych's Avatar
Default Crankshaft leak
i just notice i have a leak on my rear crankshaft seal, i only have 53k, is that a common problem and i wounder why it happend, the milage is not that high
Old 08-13-06, 11:48 PM
RA0806232
RA0806232's Avatar
Me too!! Same problem with my 91 LS400. Have vibration through complete operating range - gets worse above 140. Had driveshaft removed and balanced and new ($195.CDN) hanger bearing installed. Vibration still there maybe a tad worse - definitely not better! Anyone else out there fixed such a problem. I'm thinking axles or bearings next??
mm88
13
06-02-14 06:15 AM
mickwheelz
07-23-11 07:24 PM
Horsepwr
04-03-09 11:40 AM
Lucien911
Suspension and Brakes
11-07-08 04:27 PM
dunn378
01-03-03 11:02 AM
Quick Reply: Strange Vibration in the Rear
