UCF10-11 Rotor / Caliper Swap?
Old 08-19-06 | 03:15 AM
  #46
94lex83457's Avatar
94lex83457
Originally Posted by Phucanese
yeah, i bet i can find some for $100 rebuilt.
just call up some of your local auto-parts (not the big name ones).
and they should have some, or can order some for that price.
dont go to the dealers, theyll charge much more.
here is where i usually get parts from.
http://www.halseyimportparts.com/index.htm
it is in Portland, OR. so i dont know if they will ship.
i havnt check for the calipers yet, but for example, they can
get brake rotors for a Camry for 25 bucks each....
I am lucky to live in the portland area so I can drive over to the east side, but my question: how is the quality on rebuilt calipers or rebuilt anything for that matter?
thanks, joe
Old 08-19-06 | 12:44 PM
  #47
Phucanese's Avatar
Phucanese
thanks, joe
rebuilt is as good as new parts.
when you buy alternators/starters/transmissions/calipers/etc. from the dealer, they send you rebuilt ones.
so you dont have to worry about the quality, because they are basically factory.
Old 08-21-06 | 08:11 PM
  #48
skperformance's Avatar
skperformance
I was talking about the fronts ,i have no experience in looking at the rear brakes for comparison.
Old 01-14-07 | 04:53 AM
  #49
bigmalik00's Avatar
bigmalik00
is upgrading to 2004+ calper out of the question?
Old 01-14-07 | 12:40 PM
  #50
avalon42's Avatar
avalon42
Originally Posted by ls400boi
I did install steel brake lines from Goodridge as well.
My rotors are starting to wear down and I bought some Goodridge SS lines, and then read about the Supra TT brake upgrade...I have one question:
Which Goodridge SS kit will work with the Supra TT brake calipers? There are two different SS kits, one for 89-7/92 (kit no. 21101) and 8/92 to 94 (kit no. 211012). Since your car is a 90, I'm thinking you used kit no. 21101, rite?
Old 01-14-07 | 12:58 PM
  #51
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100000
yes, unless u fab up a TON of purely custom (and very expensive bracketry)
Old 01-14-07 | 01:00 PM
  #52
PureDrifter
BahHumBug
CL Folding 100000
it should still work but why go with the TT kit? there is a minimal performance difference between the TT and the 2LS upgrade but the 2LS upgrade is both MUCH cheaper and a decent bit lighter. hell, even Aliga runs 2LS calipers on his SC and we all know how many TT kits he sells.
Old 02-07-07 | 05:51 PM
  #53
turbosix's Avatar
turbosix
let me just run this by you guys again...... to make sure i read correctly
details:
1. i have a 1992 LS
2. i need new rotors bad, they are warped like hell.
from what I read, I can go to autozone (or wherever) and buy a set of 1995-2000 calipers and rotors and they will BOLT ON to my spindles with nothing else changed? eg...
1. remove wheels
2. disconnect brake lines
3. remove calipers
4. remove rotors
5. install new rotors
6. install new calipers
7. connect brake lines
8. bleed brakes
9. drive
I was going to buy some new rotors but if this is the case I will hold out and get some calipers too...
Old 02-07-07 | 06:19 PM
  #54
PureDrifter
BahHumBug
CL Folding 100000
yes, they will bolt on, you will have to bend or cut the dust shield slightly to fit the caliper, very minor stuff.
only 1 BIG problem.
THE BRAKES WILL NOT FIT UNDER YOUR WHEELS.
nope. no way in hell the 2LS brakes will fit under ur stock wheels. (at least not without major spacers.)
Old 02-08-07 | 12:16 AM
  #55
turbosix's Avatar
turbosix
damn... looks like i will have to get some GS 17s first...
thanks for the heads up
Old 02-08-07 | 12:19 AM
  #56
PureDrifter
BahHumBug
CL Folding 100000
ehh, sorry but the GS wheels wont clear either
unless u mean the NEW GS.
only wheels that will clear are 95+ LS400/LS430 wheels. 2IS wheels SHOULD work too.
Old 02-08-07 | 01:36 AM
  #57
1uzfelbc's Avatar
1uzfelbc
Hey how about the rears, are there any upgrades for them?
Old 02-08-07 | 01:56 AM
  #58
PureDrifter
BahHumBug
CL Folding 100000
not that are known atm.
the supra TT rears dont fit for sure.
Old 02-10-07 | 10:47 AM
  #59
turbosix's Avatar
turbosix
whaa.. damnit... would small spacers work then? i figured you meant the rotor/caliper would not clear on the rim of the wheel ....did not know you meant the calipers would hit the spokes
Old 02-10-07 | 08:41 PM
  #60
PureDrifter
BahHumBug
CL Folding 100000
these brakes actually stick out further than most BBKs.
spacers would work (prolly 15mm) but ud need longer studs too.
buy some LS430 or NEW IS/GS wheels, they can come and go cheap.
i saw a set of stock 2LS 16" wheels go on ebay a couple times for <$300.
