Easiest Way to Replace EGR Valve Pipe on 95 LS400??
Old 08-18-06, 07:42 AM
DroppedGS
DroppedGS's Avatar
Default Easiest Way to Replace EGR Valve Pipe on 95 LS400??
I have a 95 LS400, im just wondering whats the easiest way to replace pipe? I hear its different changing pipe on 90-94 LS's.. Whats the dfferance?
Old 08-28-06, 05:42 AM
Strida
Strida's Avatar
The difference is the egr pipe is cut in two, lower and upper. It is separated by the coolant bridge. The lower one is a pain because it is attached at the bottom of that damn coolant bridge, which is hard to get to.
Old 08-28-06, 05:46 AM
DroppedGS
DroppedGS's Avatar
What do you think would be the easiest way to get the EGR Pipe out on a 95 LS?
Old 08-28-06, 11:10 AM
bicol-ini
bicol-ini's Avatar
hi drop the tranny, thats what i did some years back, so you can have full access to it, you can also try not to drop the tranny if you have small hands, its do able somebody did it but its a huge PITA in my opinion not worth all the effort. thats the bad news, good luck
95lsUCF20
11-10-17 08:14 PM
yuyo
20
05-25-13 07:57 PM
LilMan23
02-10-12 11:07 AM
jgabem
09-16-10 02:49 PM
jgabem
09-16-10 03:30 AM
Quick Reply: Easiest Way to Replace EGR Valve Pipe on 95 LS400??
