H3C HIDs???
How the hell can I upgrade my h3c wire harness halogens to, say, a yellowish HID????????? What kinda modification will it take?
I searched h3c on the site, found NOTHING.
I have a 93 LS, UCF11....anybody know how? PureDrifter?
Will a regular h3 work with SLIGHT mod?
Thanks in advance!
Thanks in advance!
running HID fogs is not a issue and requires no harness mods, if you put a relay in you will be fine, and if you want yellowish light you might want a 3000k or 4000k bulb
Yea..me either, but if you goto www.lexls.com
Under the Lighting section, he has the same tutorial they made up on there for converting H3C into H3.
So...PureDrifter, is it possible to make the fog lights turn on by justing flipping the fog on, rather than turning my low-beam on AND the fog on switch? Because that's what I have to do now....and the purpose for me getting fogs is to use them independently, it will look like *** with the 3000k fogs AND my 6000k HIDs on together...
is this possible to rig them independently?
Found the link for you:
https://www.clublexus.com/forums/sho...ight=fog+light
