LS moans below 40 mph??
Old 09-20-06, 08:33 PM
hobaid
hobaid's Avatar
Default LS moans below 40 mph??
Hi all, recently my LS has started moaning with light vibration in the gas pedal when I'm at or below 40mph. This doesn't seem to happen when I accelerate quickly, but happens when I'm maintaining a speed of up to 40. Any thoughts why this could be happening??
Thanks.
Old 09-20-06, 11:24 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
This could be a number of things. Could be your tranny needs fluid replaced (specifically, Torque converter)... I had the same problem with an older car when overdrive first engages, and throws the engine in low RPM.
But also can be caused by something else. How clean in the tranny fluid? Does this only happen in the morning? or at anytime? oh and how many miles btw?
Old 09-21-06, 10:17 AM
RA40
Super Moderator
RA40's Avatar
On mine, the resonance from the tires vibrates anything that is remotely loose. Also have a sound that seems like a spedometer cable but I think the LS is electrical opposed to mechanical. Similar sound the speedo cable in the Cressida made when the grease wore from the the cluster connection.
Old 09-22-06, 10:27 AM
hobaid
hobaid's Avatar
Thanks for replying. I don't know how or where to check the tran fluid. I'll have to refer to the manual. will get back to you asap.
I've got a 1991 LS 400 with 136000 miles on it. What does btw stand for?
Old 09-22-06, 11:29 AM
RA40
Super Moderator
RA40's Avatar
BTW- By The Way.
Old 09-24-06, 04:12 PM
hobaid
hobaid's Avatar
I checked the trans fluid & it clear with amber/red hue. What do you guys think?
Old 09-24-06, 04:47 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
engine/trans mount perhaps?
Old 09-24-06, 04:54 PM
hobaid
hobaid's Avatar
Is there any way to check PureD?? Or where should I take it to get it looked at?
Old 09-24-06, 04:59 PM
hobaid
hobaid's Avatar
Also if that is the problem about how much should I get ready to spend?
Thanks
pito
pito's Avatar
I think you need to get more specific with your symptoms.
Where is the sound coming from?
Smell your tranny fluid on the dipstick, does it smell burnt?
Could it be a possible wheel bearing going bad?
Sounds can be helpful if they are a little bit more specific as to location.
Old 09-24-06, 05:50 PM
Tammy
Tammy's Avatar
May be something as simple as tire rotation with tires re-balanced.
Also a good time for the tire inspection for uneven wear or cupping.
Old 09-24-06, 06:14 PM
PureDrifter
BahHumBug
the symptoms are just too generic, it could range from wind noise to motor/trans mounts to rear axle boots to a whole host of other things.
Old 09-27-06, 07:47 AM
hobaid
hobaid's Avatar
Thanks for your input everyone. I got the tires balanced & alignment done. But there's still the sound. I'll get back to you guys on the rest of your questions.
Old 09-29-06, 03:51 PM
hobaid
hobaid's Avatar
The sound seems to be coming from under the car around the gas pedal area, with occasional vibration from under the hood on the drivers side close to the windshield.
Old 09-29-06, 09:36 PM
NewLSlover
NewLSlover's Avatar
It does sound like your driver side motor mount has crapped...just my opinion.
Quick Reply: LS moans below 40 mph??
