Idle Air Control Valve
for 1990-1994 Lexus LS400..
Where is this part located:
PICS WOULD BE GREAT!
heard people calling it idle up valve, ICV, IACV, some people saying they got it for $70 bucks others saying $700..anybody know the definent answer to this?
much appreciation is greatly accepted.
thanks..
would help a lot of LS owners out.
possibly related to low idle issues...worth checking out my other posts.
thanks..
Crazimofo,
The Idle Air Control Valve and Power Steering Idle up Valve are different things. The Power Steering Idle Up Valve is attached to the power steering pump. The Idle Air Control Valve is right at the center of your engine. See attached picture.
Where is the idle up valve that can stop me from losing ps fluid & stop the smoke. Replace the high pressure hose and a new ps pump .smoke stop for 3 days as well as the leak,back again it;s a nightmare. Can some one break it down to a dummy.
This should explain it all:
https://www.clublexus.com/forums/ls4...ystem-diy.html
and this:
http://us.lexusownersclub.com/forums...showtopic=6583
and this:
It's good that you searched but next time do a little better. Posted in a wrong thread, which is 5 yrs old. Check the first link that AzHotLS posted and you'll find all your power steering fluid issues.
Thanks I'm a new member 1st thread. Corrected the problem Thanks.
Any chance some one can help me with sluggish power hard to get up to speed. I also smell gas. I change the 2 o2 sensors pre-cat converter, could I need 2 post o2 sensors & a cat ?
LS400BOY
12
01-18-11 03:12 PM
POS
06-05-04 08:47 PM
