Headlight Bulb Replacement.........100BUCKS!!!!!!!!!!!!!
I have a bulb out on the Lex. Lexus wants a hunned dollars!!!! Can anyone lead me to a more affordable sulotion? Thanks.....................Bill
his profile says 93 LS, dealer must have meant free bulb + 1 hr labor to install. go to any local auto parts store, lookup your application for whatever brands they carry and change both headlight bulbs while you're at it. then you wont have a gripe about mismatching L/R headlight output.
Remove the side marker lights to get access to the bulbs in the back of the housing. No need to remove the headlamps. See attached pic for the screw to remove to take out the side markers. Once the screw is removed the lights are just held in with pins that push into spring clips. Just pull the lights out. You will have to remove the air filter and battery to remove the bulbs from the back.(good idea to use booster cables and another battery to keep power to the car when removing the battery otherwise all the vehicles computers will be reset to factory) Don't remember if I removed the fog lights or not but if you have to you have the link above. This is not a hard job. Good luck. Group, if I have left anything out please correct me.
Bruce
Bruce
VIP|EXEstyle セルシオ
DIY (Do It Yourself)
http://www.lexusownersclub.co.uk/kno..._v2&id=191&c=7
Personally, I think it's easier if you remove the headlight assembly...I'd rather do that then remove the battery/air filter, but that's just me.
Personally, I think it's easier if you remove the headlight assembly...I'd rather do that then remove the battery/air filter, but that's just me.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
but if you remove the headlight, then you would probabbly want to re-align them, if you leave them in place and remove the parts from behind them, you won't affect the alignment at all.
good luck
Thanks for your replies. The right seems very easy, but theres no info on the left which is MUCH more difficult. Does that require removing the battery? Is it the same screw set to remove/?? Thanks again...............RaJ
