They are different finishes, it wont match your dash.
i "could" just swap the front trim, right? with 95-97, there is no ASL button (what is ASL?) and can i simply just leave it out where the 95-97 trim has no actual hole for it
You mean the FACE of the headunit? Im not sure if it comes off easily, and not sure it will fit. ASL = Automatic Sound Leveling. Adjusts the volume levels depending on ourside conditions. (higher on highway, lowers at stoplights).
You can give it a try... but I've never seen it done before.
