LS400 breaking loose in the rain
Old 11-02-06, 05:54 PM
nthach
nthach's Avatar
Default LS400 breaking loose in the rain
Well it's the first rain in the Bay Area, and my LS does have a bit of a tendency of breaking loose under moderate throttle. If I lightly throttle it, I have no problem with traction, but I was spinning my rear wheels after leaving a stop sign on an incline. I have new tires, Michelin Pilot Exaltos, and I keep my tires at 35 psi. Should I drop the pressure, and add some weight to the back? Should I also see if the TV cable is adjusted?
Old 11-02-06, 06:44 PM
RA40
Super Moderator
RA40's Avatar
With the first rain and all the slick roads, this may be typical for now. How many miles on the tires? Might take a couple runs to wear off the mold release agents but I dunno if that really effects traction like this. <shrug>
Old 11-02-06, 06:49 PM
nthach
nthach's Avatar
tires have 6000 miles on them, I need to have Costco do a rebalance+rotate soon.
Old 11-02-06, 10:49 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Decreasing the pressure will not do much good in rain conditions. Its really slippery the first few times it rains, due to all the grease build up from tires for however long it hasn’t rained.
Old 11-05-06, 12:06 PM
turbosix
turbosix's Avatar
id inflate them to 40psi or more.. whatever the tires call for.. get a few extra miles out of your tank of gas
Old 11-05-06, 06:31 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
yea, thats gonna help his wet-road traction
Old 11-05-06, 06:35 PM
GSteg
GSteg's Avatar
pumping the tires up to 40psi probably wont be the best idea.
Drop the tire pressue and put some stuff in the rear. It happens to me on my GS400 in the rain sometimes.
Old 11-06-06, 12:31 AM
Losiho
Losiho's Avatar
Have a read of this article before you immediately assume it's better to drop tyre pressures on a wet road
http://www.tirerack.com/tires/tirete...e.jsp?techid=3
Old 11-06-06, 12:36 AM
vraa
CL Folding Team Starter
vraa's Avatar
Relax, drive slower.
I had the same problem on my LS. That thing was just out of control in the wet.
Old 11-06-06, 03:22 PM
PureDrifter
BahHumBug
i had a horrible problem with this a year ago but my tires were completely and utterly SHOT.
since yours are new just drive slower
Old 11-06-06, 08:43 PM
RA40
Super Moderator
RA40's Avatar
PSM...that means he has to buy a Porsche.
Or any other traction type system as found on the newer Lexus cars.
There ya go...approval to buy a new Lexus.
holYcOO
Maintenance
02-27-09 02:11 PM
media2lexus
08-14-07 05:22 PM
Falcon LS
Wheels, Tires & Brakes Forum
09-09-05 06:14 AM
ethanhunt
03-03-02 07:29 AM
Quick Reply: LS400 breaking loose in the rain
