will a 90 LS400 cluster fit 93 LS?
Me again!
I just noticed that the 90 LS400 has analog display of the mileage as oppose to the digital display the 93 LS400 has.
My question is: Are they both interchangable dispite the difference in mileage display?
As you all know these cluster go bad after so many miles and mine is one of them. If they are both interchangeable, then I can swap mine out for one similar to the 90 LS. the only difference is that it came out of a celsior.
anyone?
anyone?
Might be a difference in a wiring harness, but I do believe that it should fit with no problem. Someone esle, please correct me if I am wrong, am speculating myself using the same rational reasoning.
as far it fitting in the hole, I beleive it will. I just need to know if the harness will match and if not...is there a way to make it work? I just want to fix mine and in the mean time use the other cluster.
ArnoldR
10-03-19 12:21 AM
