Access to license plate bulbs in 1gen LS400?
Has anyone replaced the license plate bulbs in their 1gen LS400? How do you go about doing so? I took off the carpet from the trunk and see the plugs going into the bulbs, but it's very difficult to handle them from there. Do I have to remove the taillight assembly? If not, do the bulb plugs twist off like all the brake lights or snap in?
Thanks for the help. I ended up removing the inside tail lights which made it so much easier. Kind of disappointing because after all that work I realized that the LEDs I got from eBay are so dim. I guess I'll have to go back to superlumination.com.
But at least now I know I don't have to remove the tail lights
If your talking about the rear license plate bulbs all you have to do is unscrew the four screws under the lights and then pull off the black piece and the bulbs should be hanging out already... Why take off any carpet or tail lights... ??? i took apart mines to try some bulbs and thats how i did it... i dont know if were talking about the same thing. License plate bulbs right? but no need for taking apart any carpet or tail lights...
just the clear part.
take a look at this for any interior lighting needs.
http://www.luxurymods.com/tutorial17.htm
Even shows how to change the license plate bulbs
mydakrri
03-05-19 11:09 AM
