1998 LS400 Acceleration Problem
I have a 1998 LS 400 with 48000 miles on it. I had a check engine light come on along with a VSC problem. When I tried to accelerate today it would take me a hard peddle to make the car move and a good 2-3 seconds before it would move. I put the car in neutral and gave it gas, the RPM's shot up as it would normal, however in drive, it would move as fast as it normally should.
I three days ago I changed the Battery and Front Head Lights.
Any thoughts on what type of problem it would be? Could it be a fuel filter? or something a little more problematic?
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Your car could be in 'limp mode' because of the CEL and VSC.
Forum Administrator
Did a little searching - knew I'd experienced the VSC issue when I changed my battery in my 98 LS400... this may help
https://www.clublexus.com/forums/sho...battery+change
sikkwidit
04-28-09 11:29 PM
