running amp 12v wire through firewall
#33
lol, just what i needed.. it's a good thing i came across this thread before i started looking for a hole in the firewall.. i really don't wanna drill :\ i might consider putting it through the body and bringing it in through the fender/door
having some difficulty prepping this scosche amp wiring kit
#37
continued,,,
driver side jam,,, slit was cut into carpet to make easier to feed wire thru,,
wire thru to trunk area,,, backseat was removed to drill hole for pass thru,,
hole made in trunk liner to hide wire as much as possible,, hooked to capacitor,,
MTX 12's,,,, sledgehammer series,,,, trunk area to be redone next summer,,
Hope this helps guys.
#39
hey guys, so my friend helped me wire my subs today.. and we didn't drill any holes through the firewall.. and we still got through.. the ecr or something wires going in to the back of the glovebox is what we used to get the power wire in.. we followed the wires that go from the top left ish part of the hood to the back of the glovebox.. really simple.. from there we put everything under the side sills.. one of the two clips for the seat was giving me a hard time so i couldn't remove the seat back or the rear seats, cause it wouldn't budge for some reason.. decided to remove the old sub.. put the wires behind the seats.. and get them in the trunk area via the old nak sub hole.. all in all you don't see ANY wires until you get up to the old nak sub cover thing.. even then you only see it for about 2 inches and it's straight up so it doesn't look bad.. if you guys have a question regarding anything i said.. just shoot
#40
#41
#44
Depends on the sound you are trying to achieve. If you are using free air subs, then, IMO you will get alot of rattle from the trunk area. The ones I have are not free air, and actually direct the bass into the cabin area of the car until I pop the trunk. Bass is not obnoxiously loud, until you open a door, then whoa. Very little to no rattle from the trunk area either.
