Ok to use DOT4 in 91 LS400?
Old 01-03-07, 06:24 AM
91LS400vgb
91LS400vgb's Avatar
Default Ok to use DOT4 in 91 LS400?
Was reading the label on a bottle of Prestone Synthetic DOT4 brake fluid. It says:
Good for all DOT 3 & 4 brake systems.
Recommended for all ABS, Disc and Drum brake systems....requiring DOT 3 and DOT 4 fluids.
Compatible with all conventional brake fluids.
Just wanted to ask if anyone had any opinions on the subject - i.e., is there any reason I shouldn't use the DOT 4 in my 91 LS when I flush my brake system? Thanks.
Old 01-03-07, 11:42 AM
nthach
nthach's Avatar
I do it - I have ATE Type 200 fluid in my car now, I'm switching it out to ATE Super Blue soon. DOT 4 has higher wet/dry boiling point since it also has borate esters in it - making it a touch less hygroscopic.
Old 01-03-07, 03:35 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
it will be fine, go ahead.
although i wouldnt go with prestone but amsoil, royal purple, or Mobil1
Old 01-03-07, 06:24 PM
91LS400vgb
91LS400vgb's Avatar
Thanks for your advice
Old 01-03-07, 07:07 PM
crazimofo
crazimofo's Avatar
Yup..I used it in my prelude and integra before..purple color was my dot4...
worked good...make sure you do a good evacuation of all the old dot3, before putting in the good stuff..
how much more did yours cost?
Old 01-03-07, 09:48 PM
nthach
nthach's Avatar
It's not engine oil. For brake fluid, I'd stick to Vavoline SynPower, Castrol GT-LMA, ATE Super Blue/Type 200/SL DOT 4, or Pentosin Super DOT 4.
Old 01-03-07, 10:04 PM
PureDrifter
BahHumBug
the 3 companies (except royal purple which i just realized doesnt make brake fluid) make good brake fluid but ATE super blue is also a pretty good (but very expensive) choice.
domonas
RX - 3rd Gen (2010-2015)
12
04-22-18 09:15 AM
KC98LS
06-28-16 02:21 AM
melymel96
01-12-10 01:19 PM
GS300 I6
GS - 1st Gen (1993-1997)
04-07-09 12:27 PM
Quick Reply: Ok to use DOT4 in 91 LS400?
