Engine Temp guage not returning to cold?
Temp guage only goes down to about 3/4, then as it warms up it is pegged past hot. Any ideas how to fix? Also, battery dies overnight, like something is draining it. Any common places to check? Thanks
...as for the constant drain, I think a few here have mentioned that the CD player in the trunk might be one of many systems to check.
I had a drain on my system for a while, until I realized that it was the aftermarket alarm/keyless entry system someone installed (a rather shoddy device as well). Once I yanked the system and patched up, everything runs and charges fine...process of elimination works best. Good luck.
-avalon42
2014IS250
03-12-16 01:25 AM
