1990 LS Coolant Leak
Okay, this is one of my last problems, but it is one that I haven't found the answer to in this forum.
I am slowly leaking coolant from the 17mm filler bolt that sits in at the front of the engine. It is very tight but still leaks a little as I drive. At this point I am tempted to do one of two things: put a little rubber gasket on it, or wrap the threads in teflon tape. Are either of these bad ideas, and if so, what have you done to remedy this situation?
