LS400 owners post your wheel setup
#1743
Here some from my cars recent feature on www.Lower-Standards.com
Currently running 19 x 10/11.5" - 25mm front 35mm rear fender pull/widening
http://www.flickr.com/photos/suicidns13/12080970255/http://www.flickr.com/photos/suicidns13/12080970255/ by http://www.flickr.com/people/suicidns13/, on Flickr
http://www.flickr.com/photos/suicidns13/12081360544/http://www.flickr.com/photos/suicidns13/12081360544/ by http://www.flickr.com/people/suicidns13/, on Flickr
http://www.flickr.com/photos/suicidns13/12080970705/http://www.flickr.com/photos/suicidns13/12080970705/ by http://www.flickr.com/people/suicidns13/, on Flickr
http://www.flickr.com/photos/suicidns13/12081282713/http://www.flickr.com/photos/suicidns13/12081282713/ by http://www.flickr.com/people/suicidns13/, on Flickr
http://www.flickr.com/photos/suicidns13/12081613296/http://www.flickr.com/photos/suicidns13/12081613296/ by http://www.flickr.com/people/suicidns13/, on Flickr
http://www.flickr.com/photos/suicidns13/12081283203/http://www.flickr.com/photos/suicidns13/12081283203/ by http://www.flickr.com/people/suicidns13/, on Flickr
#1747
Please need help.
I bought concave alloy wheel set.
Front 19x8,5 ET45
Rear 19x9,5 ET 40
I did not take into account front big brake caliper
I need 25mm spacer.
Can you tell me how much it will stick out from the rim of the front fender?
You can modify the front brake caliper width?
I do not want to be sticking out from under the fender.
There is a solution?
Brake caliper or front alloy wheel mod?
Front 19x8,5 ET45
Rear 19x9,5 ET 40
I need 25mm spacer.
#1748
Super Moderator
That doesn't look like it needs 25mm to clear, many instances 15mm is sufficient. You won't be able to take off enough caliper material to make a significant clearance change. Modifying the wheel is a no-no.
Is the car lowered? If it takes 25mm to clear, you'll have to put a corresponding spacer in the rear to balance the look, ~20mm. Bottom line is if it takes this much spacer, sell-return these and buy a set of wheels that fit right. If the car is lowered, you'll need fender mods and likely a stretched tire fitment for clearance after all this.
#1751
Thanks for the help everyone
I made homemade spacer. Gold bolt width 18mm. 18mm not clear the big brake caliper. I put under 2mm washers. 20mm spacer clear the brake caliper
Last photo 18mm spacer. Scratch the brake caliper.
Soon buy 20mm spacer and long stem screw. After I put the 245/45 R19 wheel. If no good then I change 245/40 R19 wheel.
#1755
Since you guys are all pro wheel people, what do you guys recommend for flush fitment on a 90 Celsior. Nothing to extreme just flush, I'm on factory air with rolled guards. Don't want to pull them though. Any ideas? Offsets?
