Hello everybody... I'm new member here" i just joined and i don't know who's to ask about this ..
I need help about wheels.. I have 1998 lexus ls400 and i just bought for it (precious rims 18 inches two widths ).. I will post pictures for them.. So i want to ask about the best tires for them.. I need tires that are comfortable and quit as much as possible.. I have to say also i live in Saudi Arabia and the temperature here in summer 51 c / 122 Fahrenheit... Help me to choose the best tires.. Thank you
Where the hell did you get that front lip?? I've been looking EVERYWHERE for that one for my '94 :P
I can't really see the other side but is that a single exit dual tip? If so got more details/pictures on it?
I've had a single pipe on my ls400 for a few years; just kept it hidden with a turn down. Had a dual tip m3 muffler at one point I was going to try but long gone now.
Will a 19x9.5 et -15 look normal on a stock rear of a UCF21? Or will they poke like crazy. It will not be slammed or cambered in like crazy.
they will poke out! i've had semi-flush (maybe slight poke) fitments using 19x10.5 +24 in the rear, which is 26mm LESS than your specs. if you don't plan on doing major fender or camber work, those wheels will NOT fit or look normal. and remember ride height and tire size are determining factors as well.
Whenever you go negative you're going to have a hard time with fitment though, I have a 19x11.5 rear but still positive and still fits, there are other ways to get fat lips Lexus777
Got 19s off scion xb but i need to know how wide i could go with the rear tires i was thinking maybe 255/40/19 how wide can i go on the 1992 without rubbing
Just picked up a set of 9.5 +24 and 10.5 +24. I haven't test fitted them yet but do you guys know if the front will clear the LS front brakes?
Also looking at picking up 235/35 for the fronts and 245/35 rears. Anyone have pics of that tire setup close to ^ sizes?
Thanks guys!
those specs should fit IF they clear the brake calipers. as shmee stated, there is no way to determine clearance with simply offset. if you have a wheel model, i can venture a guess.
here is my previous setup, 19x9.5 +24 and x10 +24 with 225/35 235/35 tires. i could have easily fit 245s in the rear so your tire spec should be ok. keep in mind not all tire brand sizing runs true, meaning a 235/35 toyo will size slightly different than a same sized nitto for example.
fyi, if i went 235 up front, it would have def rubbed my fenders, which are all shaved on all corners, no roll or pull.
Specs: 19x9.5/10.5 +22
Tires: 225/235 35/19
Suspension: BC BR extreme drop 14k/10k
Fender Work: Fronts are un touched, slight rubbing at full lock both ways, rear are cut and hammered flat for now
Alignment: Front is slightly cambered due to maxing out the oem toe arms, rear is pretty much zero'd out
Clears the big brakes as well
