I'm in need of advice and thought this was the best place to ask. I am looking at getting ESM 015 18x9.5/10.5 +15 for my LS400. I know it would need spacers to clear the calipers, just don't know what size I would need. I've been told 15mm would work, but I also spoke to a wheel rep and was told that I would need 20/25mm. Any suggestions? Thanks for any help.
Depends on the disk size of the wheel...most cast wheel companies won't give you this info however. How mmuch camber are you planning to run/how low are you going to be? 18x9.5 with an effective offset of -10 Will need at around -3 degrees and some low to pull off.
Thanks for the reply. Looking at the wheels, they look like they would be low disk. The front has ~3 in lip and the rears have ~4 in lip. My car right now is low, I just got Function and Form coilovers installed.
Raphy, might just need a light pull or even just a shave.... I have a 4 and 5 inch lip (19x10.5/11.5) and just a slight pull with some good camber. I'm bagged though.
Hello All,
Thought I would share some pics finally of my wheel setup. Work Meister SP3. 19x10" (+2) & 19x11" (+0) wheels. 225/35/ZR19 & 235/35/ZR19 tires.
808 represent! love the wheels, can't believe you can do those offsets. pretty wild.
