LS400 owners post your wheel setup
Old 06-22-18, 04:52 AM
  #2431
staygold
staygold's Avatar
My 1992 w/ 2018 Toyota Sienna 17" OEM wheels and 225/50/17 tires. Just happened to run across them online for $225 (all 4!) fresh off a new Sienna at a Toyota lot. The offset put me just under being flush with the fenders. Trying to decide if I need a drop with H&R spring but don't want to scrub... at all. Not interested in coilovers due to the firm ride.
Old 06-24-18, 01:14 AM
  #2432
RA40
Super Moderator
RA40's Avatar
Originally Posted by Stanislav
Any fender mods?
To run the Style 95's, this thread has some info and links:
https://www.clublexus.com/forums/ls-...tyle-95-s.html
Old 06-28-18, 08:00 AM
  #2433
getf
getf's Avatar
Default 1992 UCF11 Toyota Celsior on 225/45R-18 18x7.5 +48 WALD Duchalet II
Just mounted my WALD Duchalet 2 wheels on my 1992 Toyota Celsior UCF11. Tires are 225/45/18. Wheels are 18x7.5 +48.
Stock air suspension.
creilly (07-04-18)
Old 06-29-18, 02:00 PM
  #2434
EthanS
EthanS's Avatar
I really want to see this lowered a few inches. Do it now.
Old 07-01-18, 07:02 PM
  #2435
Juhman97
Juhman97's Avatar
Default 19” (2012) Lexus RX350 Wheels
1993 Lexus LS400
(2012) 19” Lexus RX350 wheels
7.5 inched wide with a 35mm offset
Wrapped in 225/45R19 Nanking AS-1’s
OEM Air-ride suspension set to “High” setting in picture
No modifications needed even with the extra 10mm poke over stock the front caliper fitment is SUPER CLOSE
Old 07-04-18, 09:40 AM
  #2436
400fanboy
400fanboy's Avatar
27%
GS430 rims, 245\45\18 OEM direct bolt-on
Suspension stock for now, still researching coilovers to lower it. Specifically the front has to come down.
Just a couple of candids
TropicTrdr (09-13-22)
Old 07-05-18, 12:23 PM
  #2437
Qbn510
Qbn510's Avatar
Default 1990 lexus ls 400
909LS , 01-24-07 10:09 PM
1990 LS 400
18x8.5+35 18x9.5+32
tanabe DF210 springs
Old 07-08-18, 05:08 PM
  #2438
DVL5WRK95
DVL5WRK95's Avatar
Originally Posted by Wheel_Man
AME Shallens
19x10 and 19x9 w/ 235/35/19's. Just installed my Function and Forms tonight. Very happy with the results.
What’s the offset on these?
Old 07-27-18, 02:57 PM
  #2439
pgk
pgk's Avatar
Hi Guys,
I have read all of the posts in this thread but still a little gun shy on purchasing wheel and tires, I'm hoping you guys can help me out. I have a 1990 LS400 that for now is totally stock, my plan was to buy a set of 18" x 7.5" 45mm LS430 wheels and mount a set of 235/40/R18's on them, then when I get the funds purchase a set of BC coil overs and drop the car a couple of inches.. Will this combo work without rubbing? I don't really want to roll the inner fender lips. I'm open to all suggestions.
Thanks in advance
Pete
Old 07-29-18, 02:43 AM
  #2440
400fanboy
400fanboy's Avatar
Originally Posted by pgk
Hi Guys,
Thanks in advance
Pete
You really want 245\45\18, it's within 0.3% of the OEM spec so your speedo' will still be accurate. I don't know if you can upsize one tick on those rims to a wider tire. Mine are 18x8 while yours are 18x7.5.
You don't need to roll and there will be no rub since the overall diameter will be nearly identical. If you drop the car "a couple of inches" then you very well might rub.
BPlove (12-13-20)
Old 07-29-18, 07:56 AM
  #2441
pgk
pgk's Avatar
Thanks for the reply Fanboy, the car still has the original wheels that are 205/65/R15 that are according to tiresize.com are 25.5 tall, 8.1" wide, 5.2 sidewall the 235/40/R18's spec out at 25.4 tall, 9.3" wide, 3.7" sidewall. I looked up the 245/45/R18's and they are 26.7 tall, 9.6" wide, Unless I'm missing something the 235/40/R18 are more closely matched to the originals? And i'm thinking that the 245's might be a little wide for the LS430 wheel at 7.5 like you suggested. I thought a read somewhere that the 1rst gen cars have smaller wheel wells than the later cars?? I'm not looking to put this car on the ground I just want to lower it a bit like a lot of the other guys on this forum, they do look much better set down a 1' or so. I wouldn't mind a slightly firmer ride as well. Slightly..
Pete
Old 07-29-18, 09:12 AM
  #2442
python
python's Avatar
Hi Guys,
Thanks in advance
Pete
i have 235-40 18's and the speedo is spot on well 1 mph off maybe
Old 07-29-18, 09:32 AM
  #2443
pgk
pgk's Avatar
Hi Python,
What year is your LS, and did you lower it? Any rubbing?
Thanks Pete
Old 07-29-18, 05:00 PM
  #2444
python
python's Avatar
92...yes,bc coil overs...if i go up a driveway at a certain angle i rub a little
pgk (07-30-18)
Old 07-30-18, 05:35 AM
  #2445
pgk
pgk's Avatar
Your car looks killer with that setup! Do you recall what offset your wheels are, and how would you compare the ride with the BC coil overs compared to stock, night and day, slightly stiffer???
Thanks again
Pete
Quick Reply: LS400 owners post your wheel setup
