New owner but long time lurker. Grabbed this 2000 UCF20 last week. Just doing a 1" drop, tint, exhaust, etc. This is 18x8 +35 with a 5mm spacer to clear brakes with 245/45r18 and 18x9 +32 with 275/40r18. Thought it actually looked pretty decent on stock suspension with those fat tires and wanted to post it up. I think the key to running 18's on the ucf20 is spokes that come all the way to the edge and fat tires.
Just picked this car up but not a big fan of the wheels.
Forte wheels 20x8.5 with 255/35r20 tires. I think its stock suspension but not 100% sure. I want to get some sc430 stock wheels instead
Motaw,
Depending on tire size and ride height they should fit.
Are you lowered? What size tire would you wrap them in?
CarGroves,
That looks great! Looks like you kept a decent tire sidewall so I bet it still rides nice. 1 inch drop will change the ride quality slightly, but will look even better for sure! Keep us posted.
Motaw,
CarGroves,
Currently stock, thinking 225/40 in the front, 245/40 in the back.
Weather was finally clear enough to get my coilovers and wheels on. I still have LOTS of room to drop in the rear without fear of rubbing, but it would be pushing it a bit.
Wheels: Avid.1 AV-06 18x8.5 +35 18x9.5 +38
Tires: BFGoodrich G-Force Sport Comp 2 225/45/18 235/45/18
Suspension: Final Konnexion Limited
Body work: Absolutely NONE
Wow, I love these wheels! I've got a 1998 LS400, and I want to order the same 18x8.5 +35 Avid1 AV06 wheels all around my car if they fit. The owner says that no body work was necessary, and he doesn't mention any spacers either. I'll be going with 225 on all. If these wheels drop in on his 1st Gen, will they also work without any mods on my 2nd Gen? Are the infamous front brake calipers the same on these cars? Any help is greatly appreciated.
Need help finding 98-00 LS wheel specs for 20x10 or 10.5
I saw one on some Vossen CVT's and now I can't find it again to see the specs. He had either 20x10 or 20x10.5 square setup (if I remember correctly). The most aggressive I've seen is 20x10 +18, on the fitment industries sight.
I'm trying to find out the widest and lowest offset wheel I can run with just a roll and pull.
If anyone can point me back to that post or if u have the info with pics (if possible), I'd appreciate it.
I want to get some wheels but the specs are 18x8 +35 in the front and 18x9 +42 in the rear asking for info about what size wheels I can run before buying thanks for the help!
