The First Gen Power Steering Bible
#181
BahHumBug
hey guys i need some help
1990 ls400 lexus
im wondering how wud i go about to delete the PS pump? i got a link to the lewd how to replace, but wat im wondering is
do i just remove EVERYTHING PS related?
i feel like itll save me a headache later on with it leaking again etc, i rather go non power steering
1990 ls400 lexus
#182
I have read this thread extensively but would like to ask for a little guidance.
Car is a 1996 LS with what I would consider a BAD power steering leak. Filled, I get about 80 miles before the whine starts. I definitely get a lot of white smoke at start and only at start.
So many questions:
1. I believe I do NOT need to replace the pump but only replace or plug the ACV. Does the smoke at start up make it clear that its a leak of the ACV?
2. What about the high pressure hose? Should that be replaced as well?
3. If I do replace the pump, do I order an LS400 pump and then order an ACV or can I just order an SC400 pump with the ACV plugged? Or does the LS400 pump already come with the ACV? I am worried that I will hand my mechanic a new LS400 PS pump and after he replaces it i still have a leak because there is no ACV in the new pump??!!
4. Given how bad my leak is, should I just go ahead and replace the alternator? I would assume that the alternator has been all gummed up but is it 100% that if the ACV is leaking (i.e. white smoke at start) that the fluid is indeed hitting the alt?
5. Any way to test alternator to see if needs replacing or is it a part that works until it fails with no signs?
6. What are typical hours for a PS pump replacement and alt replacement? I dont have time to do work myself but have a guy.
Just looking for the best way to smoke and leak without breaking the bank
So many questions:
#183
I skimmed this but didn't see anything about fluid getting past the cap on the reservior on a '93. I get some whine mostly when cold (Canada cold, lol), steering works when driving but sometimes loses boost at idle, also worse when cold, much worse.
No smoke, no leaks I can see other than that it seems to overflow past the reservior cap/dipstick, I'm thinking it needs a pump but it idle and turning with the cap off it doesn't overflow or leak, but seems a bit aerated very strange. I have removed the valve on the rack and cleaned it, also flushed 8L through the system and it remains the same, steering assist at idle improved, but still not perfect.
I'm wondering if I can seal the factory reservior cap and use a remote reservoir elsewhere? Thinking of using a reservior with a gravity feed for the pump and a return nipple just above, would have the return from the rack go into the reservior and simply feed back to the factory reservior by the gravity feed into the factory return nipple on the pump reservior.
Any thoughts would be very helpful, the alt is not that old but its getting soaked and I'm getting sick of the mess in my driveway.
#184
make sure you do not have a leak at the o-ring between the reservoir and the pump, it's just a $3 o-ring from the dealership, I'd replace it anyway
as far as a remote reservoir, if the part of Canada where you live is that cold, I would consider a synthetic transmission fluid with a low pour point before I went to the trouble of engineering a remote reservoir
go over to BobIsTheOilGuy.com and go into the transmission area of the forum and have them recommend a replacement for Dexron III that is compatible, yet very low viscosity when cold, something like a 0W-20 kind of ATF (Dexron is approximately a straight 20W)
I am thinking something like Toyota WS ATF might do the trick
#185
Thanks, didn't know about the o-ring there, that may be it. It's -18 deg today, that's about as cold as we get here, I'll look into the fluid type if the o-ring doesn't work.
Appreciate the help!
#186
#189
please don't let your local dealership JACK YOU on this little o-ring, Lexus FULL list price is only $3.10 - so please don't let any crooked dealership charge you more, they should really be giving you a discount of 25%, (online dealerships are at ~$2.38) but we have had reports of some crooked dealerships charging $8 or more for this!
It's not the 3 or 4 dollars extra I am worried about, but if they will overcharge you by over 100% over FULL LIST price on this, what would they pull on a $1000 worth of parts during a major repair?
#190
#192
you need to report the dealership that overcharged you by over 300% to the zone rep
the correct o-ring location is the smaller o-ring in your picture, those idiots overcharged you AND gave you the wrong part! - good grief!
there is not supposed to be an o-ring where the larger one is in your pic, so remove that one.
#194
often times when a job on the car seems difficult, due to a fastener that seems impossible to reach, it is because there is a tool that would make the job really easy, that you have no idea that this tool even exists
so what I do once or twice a year is hop aboard the local tool trucks (Snap-On, Matco, Mac, etc.) and just poke around for 30 minutes, looking at all of the weird shaped tools and formulating how those might help me in odd situations I have encountered before.
also be sure to visit your local harbor freight store and just browse for an hour or so every month, you will be surprised how many times you will say "well I never even knew there was such a thing" and you will know right then how this tool could have saved you in the past and will save you in the future!
#195
