datasystems air ride controller question. URGENT!!
Old 02-11-07, 11:33 PM
pRaHjeC
pRaHjeC's Avatar
Default datasystems air ride controller question. URGENT!!
me and a friend just installed my air ride controller, but we can't get it to work. it turns on and everything, but we can't get the controller to show lower than about halfway. but it doesn't lower the car at all. we can make the controller show about halfway down, then it goes back to showing normal height on the controller.
is there anything special that i have to do to set up the controller to make it work?
Old 02-11-07, 11:44 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
u double check the wiring? sometimes the japanese wiring is insanely hard to understand right o.O
Old 02-12-07, 01:10 AM
pRaHjeC
pRaHjeC's Avatar
i didnt have to wire it, i got the harness along with the controller.
Old 02-12-07, 02:24 PM
pRaHjeC
pRaHjeC's Avatar
anybody???
Old 02-13-07, 10:58 PM
crazimofo
crazimofo's Avatar
what model do you have?
Old 02-15-07, 04:38 PM
pRaHjeC
pRaHjeC's Avatar
i have a ucf10
Old 02-15-07, 04:39 PM
PureDrifter
BahHumBug
Originally Posted by pRaHjeC
i have a ucf10
of air ride controller....
Old 02-15-07, 06:44 PM
pRaHjeC
pRaHjeC's Avatar
i got the ASI65X-M2
Old 02-16-07, 02:24 PM
pRaHjeC
pRaHjeC's Avatar
damn... i was trying to get this thing working by the president's day meet but i still can't figure it out.. nobody knows at all?
Old 02-16-07, 03:17 PM
richonenz
richonenz's Avatar
Start by unplugging the controller and putting your car back to standard , this will tell you if it may be a problem with the car or the controller .
If the air sus works fine on the car then turn off the switch in the boot then disconnect the earth lead on the battery and install your controller , have a look at the male pins in the controller and on the air sus computer on the car to make sure no pins have been bent or broken , reconnect the battery , start the car then turn the switch in the boot back on , see how this goes and report back .
Old 02-16-07, 09:10 PM
pRaHjeC
pRaHjeC's Avatar
okay i did all that, still doesn't work.
Old 02-17-07, 04:19 AM
richonenz
richonenz's Avatar
Well the next easiest thing to do is try the controller on another LS of the same year , then you will know for sure if it's the controller or the car .
Old 02-17-07, 02:34 PM
pRaHjeC
pRaHjeC's Avatar
alright, thanks for the help man.
Old 02-17-07, 04:23 PM
PureDrifter
BahHumBug
did u check the switch in the trunk?
Old 02-18-07, 08:30 PM
pRaHjeC
pRaHjeC's Avatar
yeah we fixed it now. hahaha thanks man, rims going on tomorrow so i will post pictures!
Quick Reply: datasystems air ride controller question. URGENT!!
