program your remote?
Old 02-12-07, 08:20 PM
tomsmr2
tomsmr2's Avatar
Default program your remote?
Hi guys,
I recently bought a remote from ebay, and i followed the instruction to set it up, but it didn't work. Anyone try it before? or how much Lexus dealer will charge to re-program it for you.
for a 95 UCF20
Thanks
Eric
Old 02-13-07, 11:48 AM
XareeLex
XareeLex's Avatar
Lightbulb
I have a '97 LS400. I used these instructions last week to program my new remote and they worked like a charm on the first shot. I am not sure if they would work for a '95 but it's worth a try. All da best.
1. Driver's door open and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
7. With the door open insert your key into the ignition, turn to on position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, release. The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors should unlock.
Congratulations - You are done!
Old 02-14-07, 09:15 PM
tomsmr2
tomsmr2's Avatar
Thanks for your info.
I am just wondering should I press "Lock" 5 times and then "Unlock" 5 times
or "Lock" one at a time "Unlock" one at a time and thereafter?
Thanks again
Old 02-15-07, 01:21 PM
streski58
streski58's Avatar
toggle the lock / unlock button the drivers door.
lock then unlock = 1 time...do this in 1 second intervals
Old 02-19-07, 11:45 AM
tomsmr2
tomsmr2's Avatar
Thank you all....now after i changed the battery and it works fine now
Love you all
hoonami
04-29-23 09:46 AM
nesby
RX - 1st Gen (1999-2003)
03-25-19 06:56 PM
njes300
08-26-16 02:27 PM
calgaryls4
11-06-09 09:44 AM
Quick Reply: program your remote?
