95 ls400 fusebox
02-21-07, 05:19 PM
95 ls400 fusebox
where is the fusebox in the 95 ls400? and would there be a fuse that would cause my turn signals to not work?
02-21-07, 05:42 PM
Check your owners manual
Fuses are labelled as to function. Yes...your tun signal circuit is fused
02-21-07, 05:49 PM
02-21-07, 06:13 PM
i checked all my fuses and none of them are blown, is it one of the big ones or small ones?
02-21-07, 06:39 PM
02-22-07, 08:18 AM
Did you find a blown fuse??
Fuses rarely blow in lighting circuits cuz the load is steady and predictable.
If you blew a turn signal fuse, it's either because there is a short in the wiring, or someone was messin' around.....
shlomy2000
09-10-23 12:41 PM
YODAONE
17
10-24-19 04:04 PM
EazyRice1
08-14-16 04:26 AM
volkrt
12
06-07-16 03:02 AM
ATSOU
11-19-02 01:06 PM
1995 ,
400 ,
95 ,
97 ,
bos ,
box ,
clublexus ,
diagram ,
fuse ,
fuses ,
lexus ,
location ,
ls ,
ls400 ,
signal ,
turn ,
wont ,
work
