R1 Cross drilled/slotted rotors...your opinions?
Old 03-05-07, 03:18 PM
ewenpg
ewenpg's Avatar
I have heard that the surface area that slotting and drilling takes away from the surface area used to create the friction force to stop quickly is significant and that the slotting and drilling is only beneficial if there is lot of repeated braking in a short period of time. I disagree but only arriving at this conclusion through thoughts not experience. Any comments?
Old 03-05-07, 03:49 PM
steveski
steveski's Avatar
Good point. I guess I look at it like this: After I wash my car thoroughly and drive it, the brakes grab much better than before I washed it. I notice a drastic and an immediate increase in braking afterwards. I guess the reason is the washing cleans the rotors (dust, small debris, etc.) thereby increasing the rotors and pads ability to stop
I will go with EBC rotors that are slotted and dimpled. I guess I agree with the theory that the rotors will be cooler and cleaner (from the slots and dimples) and therefore the braking will be improved. When I buy them I will post remarks.
Old 03-05-07, 07:12 PM
Thermactor
Thermactor's Avatar
Originally Posted by 601LEXTACY
Well guys. They are here and I think I am in love. I will let you know what they feel like when I mount them later today.
Judging by the bolt pattern holes, those look a LOT like Raybestos RED service grade rotors that got drilled up by a third party..
Old 03-06-07, 02:30 AM
phy
phy's Avatar
I ran the stock rotors on my 96 till about 110k. Swapped to the R1's been using them for 15k miles so far, no problems at all. Even took them on a fairly long trip (8 hours, including 2 hours of stop and go). I guess 15k miles for under $200 is worth it so far to me.
Old 03-06-07, 04:15 AM
19psi
19psi's Avatar
Originally Posted by avalon42
I've heard bad things about rotors that are cross-drilled or slotted...namely, their performance in rainy weather (or puddles). Water instead of air, gets trapped in between the holes and the brake pad decreasing brake efficiency causing it to slip...is this true?
not true. just the opposite in fact. normally on solid rotors, water gets trapped between the pad and the rotor, cuasing longer stopping distances. drilled or slotted rotors give the water soemwhere to go, so that the pad can hit the rotor right away.
Old 03-06-07, 09:06 AM
RA40
Super Moderator
RA40's Avatar
Some good supplemental reading on braking:
http://www.safespeed.org.uk/braking.html
http://www.miata.net/sport/Physics/11-Braking.html
Old 03-06-07, 03:28 PM
sha4000
sha4000's Avatar
ive have those R1 rotors that i purchased off ebay about a year ago on my car for about 2 months with no problems and ive been down to Bmore and DC as well as the NYC traffic.
Old 03-06-07, 04:06 PM
ewenpg
ewenpg's Avatar
Originally Posted by RA40
This was an interesting article!!!!
Old 09-08-09, 12:26 PM
lspower
lspower's Avatar
you will be fine i drive fairly hard and brake the same im ordering my new set after about 3 years. you will be fine.
Old 09-08-09, 01:36 PM
Schnitz
Schnitz's Avatar
Slotted &/or drilled rotors are a waste of money regarding performance. I've spoken to both Stoptech & Baer and they would both never make another drilled or slotted rotor if the demand for them wasn't so high.
ewanpg was correct. They don't 'perform' anywhere near blank discs.
Old 09-08-09, 05:35 PM
Do.Man
Do.Man's Avatar
i heard the only thing is that they oxidate or watever after a bit and give it a rusty look. but other than that it is good i guess.
Old 09-08-09, 05:56 PM
hobojoe
hobojoe's Avatar
they do but if there zinc coated like mine then no rust and the only rust that does occur is where your pads rub since it takes of the zinc.....but the instant you step on the brakes bye bye rust.
Old 09-08-09, 06:18 PM
BLKonBLK98
BLKonBLK98's Avatar
personally i would never run 3rd party drilled rotors. they are just drilled oem replacment type blanks rather than performance designs.
Old 09-08-09, 07:40 PM
I'mStock
I'mStock's Avatar
It's sad how few people know this.
Old 09-08-09, 08:02 PM
Gtask8
Gtask8's Avatar
These rotors are specifically designed for race cars for a reason. Made to be swapped out after every race, typically not for street machines in the norm.
Quick Reply: R1 Cross drilled/slotted rotors...your opinions?
