problem getting into the trunk w valet key!!!
The wallet key is supposed to be a headless valet key.
If you need to get in your trunk but it is locked as well as the lockout button inside the car then remove the lower plastic panel and undo the release buttone from the dash , then just short the wires to open the trunk and then get a spare key made.
Regardless, the shorting method is the best advice I've seen so far on this thread--now that's thinking!
contact http://www.sparecarkeys.com or call them at 866-350-4199 & have a mechanical key cut by your VIN number & sent by over night mail. It won't start your car, but it will get you into the trunk
Marx
11-09-03 04:09 PM
