Quick look at non OEM and OEM drive shaft bushing
Old 02-26-07, 08:53 AM
glenmore
glenmore's Avatar
Default Quick look at non OEM and OEM drive shaft bushing
Go to ebay and seach with "lexus drive shaft bushing" and you can see a (used) OEM bushing and compare it to new knockoff bushings. The knockoffs are real cheap ~$30 each. A new OEM one is around $200! You can clearly see that the OEM is much beefier but $200? This is another example of outrageous Lexus prices. A Mercedes OEM equivalent flex disc is about $50.
I just changed my rear shocks and just with a little movement of the sway links, the rubber boots cracked, which can be expected because they are old (1990). New links? How about $60 each from Park Place! A Mercedes sway link? $7.00!
glenmore
1990 LS400
2000 C280
1991 300CE
Old 02-26-07, 12:07 PM
nthach
nthach's Avatar
if you know someone with a WorldPac account, can they get the parts from there?
DNC
03-14-16 07:01 PM
Mike_1GO
01-08-16 03:39 PM
stevenl925
05-31-09 01:24 AM
ColtSwitch
LX570 / 470 / 450 Classifieds
11-14-06 07:23 AM
Quick Reply: Quick look at non OEM and OEM drive shaft bushing
