How to tell if water pump is bad??
Old 02-26-07, 10:37 PM
DCLexus
DCLexus's Avatar
Default How to tell if water pump is bad??
I've noticed a squeaking noise coming from the front of my car. It sounds like its directly behind the radiator/front of the engine. The belt dosen't look bad, but it's probably the original. Could the belt be bad? Could the squeak be a bad pulley bearing or is it a sign that the water pump might be going? The car has 45k miles on it.
Thanks.
Old 02-26-07, 11:40 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
search .
prolly dead fan bearing or bracket.
Old 02-27-07, 08:07 PM
skperformance
skperformance's Avatar
water pump starts to leak when it is bad through a weeping hole in the bearing.
Old 02-28-07, 09:13 AM
DCLexus
DCLexus's Avatar
I don't see any leaking water. I guess thats a good sign. Maybe it's the fan bearing/braket as Puredrifter suggested. Is this a common problem?
Old 02-28-07, 12:15 PM
DCLexus
DCLexus's Avatar
I've only had the car for about a month, and it didn't make the noise when I bought it. However, over the weekend I drove through a very dusty wind/storm that covered the car/engine with dust. After that I noticed the squeak. Could the dust have gotten into the fan braket bearing? Or maybe the drive belt tensioner?
ISFFUN
Performance & Maintenance
01-29-16 08:03 AM
aznKewlguy
11-01-14 10:56 AM
andyman32
03-17-13 07:58 AM
mikal
04-23-08 03:36 PM
Quick Reply: How to tell if water pump is bad??
