P/S Fluid leak - not easy to steer.
Hello everyone, I'm new to this forum. I own a wonderful 1991 Lexus LS400. The power steering fluid is leaking although I have not seen any fluid leak on the ground as of yet.
I go through a bottle of p/s fluid every 10 days. The steering isn't real bad, but it doesn't feel free like it should. Every few days when I hear noise (because of less p/s fluid) I add some more and the noise goes away.
A mechanic told me after taking it for a test drive that he felt the power steering pump is "tired" and should be replaced, if not now, within the next 10-20 thousand miles. That was simply a guess on his part as he didn't do any extensive trouble shooting.
My question is this, should I go ahead and get a new power steering pump/hoses for $500+ or should I pay the $100 to get my car thoroughly checked out first?
Also, if anybody has any suggestions of what might be going on, please chime in. I could use all the help I can get. I certainly would rather spend the $500 toward a new 50" Panasonic Plasma than spend on my car.
Could be anything from a $2 repair to a four fiqure $$ repair. You need to be able to do some diagnosis and repair / maintennce yourself or find a competent indie to do the work.
A simple problem would be the p/s return line, a $2 repair that just about anyone can do.
glenmore
1990 LS400
glenmore
1990 LS400
thanks for the heads up regarding the sticky.
I hope my alternator is ok. Just bought the car 3 weeks ago and I already need a new steering pump. That's ok though, sooner or later it's gonna need to be done.
