Should I go with Monroe Sensa Tract or KYB shocks
Old 03-15-07, 12:56 PM
jgmcs
jgmcs's Avatar
Default Should I go with Monroe Sensa Tract or KYB shocks
I need to replace the shocks, which are better and why?
Old 03-15-07, 04:49 PM
steveski
steveski's Avatar
Do a quick search and you'll see that many old timers here advise against Monroe - performance and quality do not compare with other manufacturers like Bilstein, KYB, Tokiko, etc.). I replaced mine with Bilstein and never even considered Monroe. I see them at tire shops and think they are better for Buicks and Oldsmobiles
Old 03-15-07, 06:53 PM
RA40
Super Moderator
RA40's Avatar
If you want that factory OEM softness, the KYB GR-2 would be my choice. Lots of threads available though here and in the GS suspension section.
Old 03-16-07, 09:28 AM
steveski
steveski's Avatar
Good info. To add, the Bilstein HD's offer two spring level settings that let you lower the vehicle .5 to 1". The struts give you a stiffer rider that is close to OEM. You could use your same springs. Just my .02
Old 03-16-07, 05:21 PM
bicol-ini
bicol-ini's Avatar
go with KYB GR2 they are close to OEM
zeez88
07-13-23 01:20 PM
GS300ken
Suspension
12
06-28-13 07:53 PM
kevin.tran
Suspension and Brakes
07-17-08 06:07 PM
myLexRX
03-21-06 05:43 PM
mdfdsc300
SC- 1st Gen (1992-2000)
04-23-01 11:09 PM
Quick Reply: Should I go with Monroe Sensa Tract or KYB shocks
