need help stereo shows SEC in my ls400
my stereo was working prefectly fine yesturday but since i changed one of a fuse from my hood it shows me SEC and theft light is solid on can anybody tells me how to reset my stereo i believe its locked and i cant power on or off ..
help pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Contact the previous owner if you know who it is. Perhaps he remembers the security code. If you have the owners manual, look all through it for a hand written number - the owner might have written it in the manual. If I remember correctly, it is a three digit number, but check your owners manual to make sure.
I set the code on my 90 LS once just to see if I could set it but I immediately removed the code.
well i know the code it's just that when i turn my key to ACC OR ON my stereo is on with SEC showing on the screen and i can't enter code i tried the manual also it says when you press SCAN it will let you enter the code but in my case it's not letting me it's stays on SEC i treid SCAN hold for 5 to 10 sec then i tried PRESS 1 , 6 AND power button nothing is happening.
help please anybody do you think i should take off my all my Stereo fuses and hold the POWER button when put the fuses back in the car and let the car start will that help i read the in one of a forum it says that please help me anybody...............
rexus31
01-08-04 11:29 AM
