problem when changing spark plug wires
hi guys..
I changed my spark plugs, caps, and rotors this morning. Everything went well, except for one important detail.
I snapped the plastic cap off the ignition wire retainer. I attached a picture with a box around the part that was broken. Those parts are brittle!
Anyways, what are my options now? I called the dealership. One said that the cap is only part of the iginition coil ( which as $120 ).. The other dealership said that little cap was $29.
thanks..
Jeff
thanks..
Jeff
The boot on the ignition wire came off right? If you changed the caps, rotors and plugs, might as well do the wires too. If the boot is that brittle, it's a sure probability the wires are due for a change. Factory change is 120K miles but they probably deteriorate before then.
If it is the coil pack outlet...I think you are left with having to buy a coil pack.
Yes, the boot came off just fine, it was the plastic retainer cap which I snapped. Kinda of shocking that they would put a cheap/brittle plastic piece on such an important piece of the ignition system.
I am off to the stealer to buy the @#$% $29 plastic piece. Maybe I'll treat small plastic pieces with more respect now..
quick update.. I went to the dealer and after looking more closely at the part, they initially quoted me for the wrong part.
The parts are about $8 each. Much more reasonable for a plastic cap. Bad news is that they have to order it ( no dealerships have it locally), so I'll be car less for a few days.
Here's an update.
Got the proper cap from the dealer. about $8 each.
here are the part #'s for future reference:
19539-50010
This one is marked with a "C" and is located near the top of the engine
19539-46010
This one is marked with an "A" and is located near the battery
19539-50010
19539-46010
ditto.
but he does own a lexus and I believe more than half of us LS owners are pretty wealthy. I myself am not.
so zip ties are a must!! that and some bailing wire and a good old innertube....
JK
I'm glad I found this topic. I did the same thing last night. Both of the caps basically shattered when I tried ot remove them. i could do the zip tie thing but will most likely go ahead and buy the caps for piece of mond if nothing else.
I really appreciate you posting the part numbers.
Here's an update.
19539-50010
19539-46010
19539-50010
19539-46010
Description Qty MSRP Price Your Price Core Total
Collision Catalog - Lexus
#1 2001 - 2005 1 $4.17 $3.46 $0.00 $3.46
OEM Catalog
HOLDER, RESISTIVE CO 1 $3.69 $3.06 $0.00 $3.06
your're welcome gunnut. I was hoping that my info would be helpful to somebody and your response was much more constructive than turbosix and lorenzo816's responses.
Well worth it in my opinion.
JimA
Drofseh
Performance & Maintenance
12-15-14 11:24 AM
flipinsayi
GS - 1st Gen (1993-1997)
05-11-09 10:05 PM
