What can a bad radiator cap do to your vehicles cooling system
Also, what are the symptoms of a bad cap, what signs do you look for, when there is no overheating present, and the needle is right in the middle.
Great point and very true - my previous 300Z started over heating and after several trips to the shop the mechanic took the cap off and the small rubber gasket had a slight rip in it - enough that when it expands from the heat it blew off steam
Easy and cheap remedy if your ride is overheating.
